Forum: ARM programming with GCC/GNU tools how can I get rid of impure_ptr ?
von anotherbrick (Guest)
hello dear forum ,
I am trying to compile a C program for STM32F407 microcontroller
with OlimexODS  ( Eclipse + yagarto compiler )
I get the error;
undefined reference to `_impure_ptr'
there is no function "impure_ptr" in my whole project
the error pointer points to a line containing only }   - see attached
screenshot
yagarto version :
This build of yagarto use the following versions:
binutils: 2.20.1
gcc: 4.5.1
newlib: 1.18.0
gdb: 7.1
(13.08.2010, mifi)
In my code I include
#include <stdio.h>
#include <string.h>
this must be something related to C compiler however I dont know what
how can I get rid of this ?
thanks
von Johann L. (gjlayde)
Don't use a debugger, it won't tell you the root of the problem.
Read the map file, generated with -Wl,-Map,filename.map and what object
needs _impure_ptr.  Presumably it's not a function but an object needed
by functions from libc.
You can also read the generated assembly (*.s) and precompiled sources
(*.i resp. *.ii) by means of -save-temps -g3 -P and ready them to find
what causes the problem, but most likely you will find the information
in the map file.
Maybe a
void *_impure_ptr;
 kludge in one module does what you want.
Are you sure you don't have a misconfigured toolchain and no objects /
libraries are missing for some reason?
The problem is not in the compiler, dig newlib.
I suspect exactly the same thing
there must be a switch or a property to be turned off
to turn off the compiler or linker option
which causes this error
This topic is locked and can not be replied to.
