http://tinyvga.com/vga-timing/640x480@60Hz
You have to implement everything, front-porch, back-porch, sync-pulse
This is my 1024x768 pixel vga. you can us ist freely and fit it to your
needs (adapt the timings).
In my case gave the horizontal and vertical counters OUT and generated
in another module the bin IN signal. This draws an white pixel when bin
is 1.
The needed 75mhz clock can be generated using an dcm.
1 | --1024x768 VGA
2 | --if bin='1' then pixel is white
3 |
4 | library IEEE;
5 | use IEEE.STD_LOGIC_1164.ALL;
6 | use IEEE.numeric_std.all;
7 |
8 | entity vga is
9 | port(clk75_in, bin : in std_logic;
10 | horizontal_counter : out std_logic_vector (10 downto 0);
11 | vertical_counter : out std_logic_vector (9 downto 0);
12 | red_out : out std_logic_vector(2 downto 0);
13 | green_out : out std_logic_vector(2 downto 0);
14 | blue_out : out std_logic_vector(1 downto 0);
15 | hs_out : out std_logic;
16 | vs_out : out std_logic);
17 | end vga;
18 |
19 | architecture Behavioral of vga is
20 |
21 | signal hc: integer range 0 to 1328;
22 | signal vc: integer range 0 to 806;
23 |
24 | begin
25 | horizontal_counter <= std_logic_vector(to_unsigned(hc,11));
26 | vertical_counter <= std_logic_vector(to_unsigned(vc,10));
27 |
28 | --Picture starts with sync-pulse
29 | process
30 | begin
31 | wait until rising_edge(clk75_in);
32 | if (hc >= 280 ) -- 280 = Sync-pulse + Back-porch
33 | and (hc < 1304 ) -- 1304 = Sync-pulse + Back-porch + Visible-area
34 | and (vc >= 35 ) -- 35 = Sync-pulse + Back-porch
35 | and (vc < 803 ) -- 803 = Sync-pulse + Back-porch + Visible-area
36 | then
37 | if bin = '1' then
38 | red_out <= "111";
39 | green_out <= "111";
40 | blue_out <= "11";
41 | elsif bin = '0' then
42 | red_out <= "000";
43 | green_out <= "000";
44 | blue_out <= "00";
45 | end if;
46 |
47 | else
48 | red_out <= "000";
49 | green_out <= "000";
50 | blue_out <= "00";
51 | end if;
52 | if (hc > 0 )
53 | and (hc < 136 ) -- 136 = Sync-pulse
54 | then
55 | hs_out <= '0';
56 | else
57 | hs_out <= '1';
58 | end if;
59 | if (vc > 0 )
60 | and (vc < 6 ) -- 6 = Sync-pulse
61 | then
62 | vs_out <= '0';
63 | else
64 | vs_out <= '1';
65 | end if;
66 | hc <= hc + 1;
67 | if (hc = 1328) then --1328 = Whole-line
68 | vc <= vc + 1;
69 | hc <= 0;
70 | end if;
71 | if (vc = 806) then --806 = Whole-frame
72 | vc <= 0;
73 | end if;
74 | end process;
75 |
76 | end Behavioral;
