Forum: FPGA, VHDL & Verilog 8bits to 7segments decoder
Author: werner (Guest)
Hi, im trying to make a 8bits to 3digits 7segments decoder usind a
double dabble, but there is something wrong with my code and i dont know
what, can you help me?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
  package my_pkg is
    function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector;
  end package my_pkg;
  package body my_pkg is
    function to_bcd (bin : std_logic_vector(7 downto 0)) return std_logic_vector is
variable i : integer:=0;
variable bcd : std_logic_vector(11 downto 0) := (others => '0');
variable bint : std_logic_vector(7 downto 0) := bin;
begin
for i in 0 to 7 loop
bcd(11 downto 1) := bcd(10 downto 0);
bcd(0) := bint(7);
bint(7 downto 1) := bint(6 downto 0);
bint(0) :='0';
if(i < 7 and bcd(3 downto 0) > "0100") then
bcd(3 downto 0) := bcd(3 downto 0) + "0011";
end if;
if(i < 7 and bcd(7 downto 4) > "0100") then
bcd(7 downto 4) := bcd(7 downto 4) + "0011";
end if;
if(i < 7 and bcd(11 downto 8) > "0100") then
bcd(11 downto 8) := bcd(11 downto 8) + "0011";
end if;
end loop;
return bcd;
end to_bcd;
  end package body my_pkg;
entity termometro is
port (
  clk: in std_logic;
  data: in std_logic_vector(7 downto 0);
  Di: out std_logic_vector (6 downto 0);
  Vtc:out std_logic_vector(3 downto 0));
end termometro;
architecture behavior of termometro is
  signal bcd1, bcd2, bcd3: std_logic_vector(3 downto 0);
  type segs is(se0, se1, se2);
  signal seg_atual, prox_seg: segs;
  signal S1, S2, S3: std_logic_vector(6 downto 0);
  begin
    bcd1<=to_bcd(3 downto 0);
    bcd2<=to_bcd(7 downto 4);
    bcd3<=to_bcd(11 downto 7);
  process(bcd1, bcd2, bcd3)
  begin
  WITH bcd1 SELECT
  S1 <= "1111110" when "0000",
      "0110000" when "0001",
      "1101101" when "0010",
      "1111001" when "0011",
      "0110011" when "0100",
      "1011011" when "0101",
      "0100000" when "0110",
      "1110000" when "0111",
      "1111111" when "1000",
      "1111011" when "1001",
      "0000000" when others;
  WITH bcd2 SELECT
  WITH bcd3 SELECT
  end process;
  process(clk) is
  begin
    if(clk = '1' and clk'event) then
      seg_atual<=prox_seg;
    end if;
  end process;
  process (S1, S2, S3) is
    begin
        case seg_atual is
          when se0=>
            Di <= S1;
            Vtc<= "0001";
            prox_seg <= se1;
          when se1 =>
            Di <= S2;
            Vtc<= "0010";
            prox_seg <= se2;
          when se2 =>
            Di <= S3";
            Vtc<= "0100";
            prox_seg <= se3;
        end case;
      end process;
end behavior;
> but there is something wrong with my code and i dont know what
Do you have a test bench for the code?
Really your code?
    bcd1<=to_bcd(3 downto 0);   -- 4 bits input for a 8 bit function?
    bcd2<=to_bcd(7 downto 4);f
This looks for me like more like:
"I have copied some pieces of code from somewhere, do not understand
even one line, and its not working like i expected! Whats wrong?"
So, first try to understand what to_bcd does and how you have to use it.
A hint: you only have to call this function once.
You can do this here much more compact, if you convert only one digit
(the one to be displayed) and multiplex the bcd input instead of the
segment /output/:
  begin
  WITH bcd1 SELECT
  WITH bcd2 SELECT
  WITH bcd3 SELECT
  end process;
i've made this code by using one that i've found on the internet, i used
a double dabble(and i understud it) code with a sweep code for 7segments
that i've(not from internet) made sometime ago that showed the word
'DATE' and 'HORA' for example on a 4digit 7segment display, it showed 1
letter each clock time on a diferent digit, so i use a realy fast clock
and it looks like that it was appearing simultaneously, i just try to
join the 2 codes, i didnt found it anywhere
BUTT i doesnt work, no matter what i try, and i tryed alot, and i dont
know what is wrong with it, thats why im asking on this forum
but thx for the tip, ill try it
Author: TheMason (Guest)
One thing i have noticed :
you used copy&paste to decode 4 bits to a 7-segment digit, but you
forgot to change the destination register.
your bcd1 bcd2 and bcd3 all (!) work on only S1. I think bcd1 should be
decocded in S1, bcd2 in S2 and bcd3 in S3, i seems to make more sense,
than using only S1. And anyway, later on you use S2 and S3 without
having made an assignment. perhaps this is the reason why it won't work.
  • [vhdl]VHDL code[/vhdl]
