Forum: FPGA, VHDL & Verilog Board recommendation for scientific computing
Author: Mem Maakers (Company: none) (memmakersorg)
My main goal for now is to build circuits that can do stuff like:
 . Simple vector computation -- add, multiply, subtract two or more
vectors
 . Work with my main driver programs ... say that read the vectors from
a file -- configure the FPGA board -- work on LINUX
 . Let me build ALUs of arbitrary precision.
 . I Do not need to do any external interfacing
 . I have never worked with FPGAs, VHDL or Verilog before
 . Studied EE 15+ years ago, was a competent student.
Was looking at the following board to get started any thoughts?
  Xilinx Virtex XCV300E PCIx FPGA board -- $40 on ebay
For someone with my needs what else should I look for that I can pick up
on ebay?
For someone with my background would you recommend resources:
1. Books
2. Tools (open source preferable)
3. Sites
Thanks in advance.
> 1. Books
If you tend to VHDL, then: Peter Ashenden
You must install the vendors toolchain, because MAP and Place&Route
are vendor specific, because huge knowledge of internal structure of the
FPGA is needed.
> 3. Sites
Xilinx, Lattice, Altera...
Every FPGA is able to...
> say that read the vectors from a file
> -- work on LINUX
Could you clearify this point much more?
No problem with any FPGA.
So, how do you connect "your" CPU?
Or do you want to build your own CPU on a FPGA?
Better to look for a "Basys" board from Digilent for the start. Or do
you need the PCI interface? Then you will need a PCI core also...
Hi @lkmiller, many thanks for your response -- I should have come to
this forum 1st.
On interfacing (stupid me ... forgive me I have been away from hardware
for a long time).
What I meant was I DO NOT need to interface to USB, serial, VGA, etc. I
DO need to get large amounts of data from memory on a computer running
LINUX on a traditional x86 based platform into my FPGA and the results
out again back to memory. So I guess a PCI (or ePCI, PCIX, etc.)
interface would be necessary.
VHDL or Verilog or something else
For what I am planning to do is one suitable over the other?
Author: RB (Guest)
If you want to use Xilinx FPGAs you might be interested in Virtex5 and
Virtex7 evaluation boards. There are some with PCIe available. But these
Kits are anything but cheap...
The VHDL/Verilog programming software is Windows-based but you can use
Linux after you have your FPGA-PCI(e)-device running.
http://www.xilinx.com/products/boards_kits/virtex5.htm
http://www.xilinx.com/products/boards-and-kits/EK-...
Hi @RB, thanks for the answer.
That is why I asked if:
would do.
I can find affordably on ebay.
Is that not what I'm looking for -- will support be outdated for it.
Also, I'm specifically not looking for Xilinx but really PCI support.
Thanks.
If PCI troughput is enough for you then I would urge you to use the
"simple" PCI interface after doing the even simpler "blinking LED" or
a "chasing light" turning over to a VGA interface, RS232 and so on (you
will crash hopelessly, when you start with the PCI bus directly).
Is C or Java the language to reach heaven? Is Spanish or English more
suitable to communicate? Its the same with every language: using the
correct words and syntax you will reach your destination...
Lets say it in a very simplified way: Europe = VHDL, Americas = Verilog
>> XCV300E
Virtex 3 are fairly old devices from the end of the last millenium. This
FPGA is no more in the part list of the current Xilinx ISE toolchain.
And this trend will continue...
Conclusion: look for newer devices (e.g. Spartan 3).
And also you will have to look for an open PCI core (opencores.org) or
buy one or write one yourself.
My tip: buy any very simple board and start with VHDL/Verilog. After
half a year playing with it you have gatherd enough knowledge to assess
further actions. You will be able to sell this small board with almost
no monetary loss.
  • [vhdl]VHDL code[/vhdl]
