Forum: µC & Digital Electronics eLua on STM32F4discovery
Author: Thomas M. (Guest)
Hi, i'm trying to run eLua on a STM32F4discovery board.
I downloaded and flashed this image successfully:
http://dd.homeunix.com/home/space.php?uid=1&do=blo...
http://dd.homeunix.com/home/attachment/public-File...
But how can i send a Lua-file to the board?
I tried to connect the board with this adapter:
http://www.pollin.de/shop/dt/MzY5OTgxOTk-/Bausaetz...
I used the Ports PB6 and PB7 for RX/TX and "Hterm" to establish the
connection, but the eLua shell did not work...
Author: Martin Thomas (Guest)
- re-try with a 3,3V transceiver, the mentioned device from Pollin is
fro 5V operation
- PB7 RX and PB6 for TX should be ok
- the lua startup-message should show up (115200,8,n,1)
- shell should react on commands typed from terminal (i.e. help)
- use the recv command in the shell and a terminal-software which can
transfer files using XMODEM to test a script
- scripts can also be placed in a filesystem (i.e. the ROMFS, needs
rebuild of the binary)
(I have used the source from
https://github.com/jsnyder/elua/tree/bikeNomad-master and build the
binary myself for my tests.)
Author: Chris Z (Guest)
Hi;
Does this mean you have done a STM32F4 build of v0.8 that supports
ROMFS? Would you be willing to post the binary?
Thanks,
CZ
