Forum: FPGA, VHDL & Verilog Spartran 3E fpga
von sophie l. (Company: genie consulting) (sophie)
hello
during this month, i must design an embedded system on a spartran 3E
,FPGA wich contains a procesor type CPU plasma, i'm looking for some
ideas!
i wanted to ask you please if you can suggest me projects? thank you in
advance
What is a "processor type  CPU plasma"?
Can you clarify what knowledge and what hardware you have and what you
have to do with that?
the main objective of the project is to design, build and run a complete
embedde system on FPGAboard, this projet is based on the plasma
processor which is MIPS processor avaible at opencores.org website aong
hundreds of other designs {{{{ the plasma CPU is a small synthesizable
32bit RISC mmicroprocesssor, the plasma cpu executes all MIPS user mode
instructio except unaligned load and tore operations ,the plasma system
also contains abidirectionel serial port, interrupt controller and
hardware timer , ddr sdramcontroller thernet mac,flash interface . this
cpu core is implemented in vhdl with either 2 or 3 stage pipeline it s
runnig at 25 MHZ on a XIllinx FPGA
,so it s expected to us (me and 2 other students ) to play a certain
role in project, HW desiger (design of hardware component,and associated
low level drivers so as  to grant software access to hardware ), SW
designer( design of the application , comprising access to the hardware
module for carrying out certains functionalities  ,System
integrator(definition ofinterface, simuation and FPGA prototyping)
the basic proposed direction lies in compute acceleration : a number of
popular algoritm are known as being CPU intensive and implementation
ofte make use of accelerator (dsp ,gpu)that handle the compute kernel
while the rest of the application still runs on the processor
the objective also is to achieved the highest possible performance by
means of using an accelarator onnected on the bus
=====>design of a generic accelerator (hw) attaching the module to the
MIPS bus (HW)
=====>design of a driver for enabling software access(HW,SW,SY)
validation through some simple example (SY°)
======>software implementation of the chosen algoritm (SW) ùax
performance assessment (SW, SY)
=======>design of a didicated compute accelerator based on thegeneric
one (HW ) implementation (HW, SY) design of the driver ( HW, SW)
validation (SY) and performance (SY)
our fpga board =>povide numver of analog and digital interfaces PS2, USB
ethernet multitasking microkernel (OS) with TP/IPstack
I am looking fo an idea of project , i really need it a consistant idea,
please may you suggest us some ideas
thank you again
