Forum: ARM programming with GCC/GNU tools Do we still need to write "efficient" C-code targeting ARM? Or does compilers do the job?
von IA (Guest)
Hello there,
I have been reading some articles, and even books, about C-code styling
to guarantee efficient machine code on ARM platforms. This is an
example:
"ARM System Developer's Guide: Designing and Optimizing System Software"
Some of those articles date back to early 2000's, and I am not sure how
sophisticated the compilers now are. Does anyone know whether such
"tricks" still matter during development (e.g. using count-down loops,
avoiding huge structures as function arguments, avoiding too many
function arguments, etc) still matter? Or does a typical compiler now
does it all?
If the compiler now does it all, does this mean that we can take for
instance the C/C++ source code that was targeting an x86 architecture,
and recompile it with a "good" compiler targeting ARM, and we may end up
with efficient code execution on the ARM platform?
Thanks in advance!
von Hmm (Guest)
>Or does a typical compiler now does it all?
Im sorry to say that, but I think that this question is lacking some
reflection beforehand.
The examples you listed are NOT recommended because:
The compiler in or before the year 2000 didn't know how to efficiently
transfer great structs by parameter. This is even in the year 2012
something inefficient which could by NO means ever optimized away.
This is the same for parameter lists. Think yourself: How could any
optimizer reduce are parameter list (supposed we do not consider simple
cases where a parameter is never used or may be derived by a
comparatively simple rule from another parameter)? Just by subtracting a
one and leaving a parameter? No optimizer, at no time in no future, as
distant as thinkable, can do that! How could he? That would have a
serious impact to the algorithm itself for which the program author is
reliable not the compiler.
The third example is a bit more specific. Most processors have faster
instructions for a conditional jump where the condition is a comparison
with zero compared to those instructions where the condition may be any
arbitrary integer. Under this condition it is every language for every
compiler recommended to use count-down loops. The reason lies in the
executing processor not in the compiler. How could any compiler modify
the instruction set? It couldn't! It could select another instruction.
But there are (for some reasons you should explore by yourself) no such
instructions which have no speed penalty.
Optimization as you understand it, was never an objective. It had never
the target to optimize away language inherent properties. Why should it?
I wish I could bring it to a point, but that's not that easy.
Optimization mainly attempts to find code sequences which are doubled,
or logically (mathematically) clueless and may be omitted. I don't want
to go into depth, because that's a very, very, very wide field, but I
talk about something like an attempt to multiply any arbitray integer a
by one. Optimizers will remove the multiplication by one.
Kind regards...
von IA (Guest)
Thanks for your detailed reply... Please let me place my arguments below
(keeping into consideration that after all, I am not an expert
programmer)
"The compiler in or before the year 2000 didn't know how to efficiently
transfer great structs by parameter"
- I meant (pointers) to large structures. AFAIK, it is recommended to
keep structures within reasonable size for more efficient de-referencing
of internal elements (less memory loads). For the same reason, it is
also advisable to place smaller structure elements first (to avoid large
elements at the beginning of the structure that may cause inefficient
access to later smaller elements). Also, different orders of the
elements within a structure result in different sizes of the overall
structure in memory (different packing/padding). Compiler maybe able to
split large structures to a hierarchy of structures? Also, it may
reorder the elements of a struct for efficient memory
footprint/bandwidth.
"How could any optimizer reduce are parameter list"
- Group them into structures, and pass a pointer to this structure
rather than passing them as individual arguments?
"Under this condition it is every language for every compiler
recommended to use count-down loops. The reason lies in the executing
processor not in the compiler. How could any compiler modify the
instruction set?"
- No... compiler won't change instruction set, but can it (for example,
and where possible) replace a count-up loop with a count-down one to
make use of the "free" comparison with zero.
- Finally, if I have C/C++ source code that runs efficiently on x86, do
I need to consider modifying the source code if I need to recompile it
to run efficiently on ARM?
von Sam P. (Guest)
Thr rule is simple: Don't write optimized code.
Use efficient algorithms, but do not bother with processor-specific
optimizations. Micro-optimizations cost a lot of time and make your code
less readable. The time saved is better invested in finding a faster
algorithm for your problem. That gives more speed-up.
There are important exceptions to that. But your very first thought
should always be: Is that which I'm about to write still easy to
understand after 12 hours of tiresome coding? By someone else than me?
If that is not the case, you will waste a lot of your time and introduce
bugs, and your little optimizations may even become pointless.
Now to exceptional cases: Start optimizing when your program is too slow
or uses too much RAM/Flash/whatever. Not earlier. Even then, first try
to find a better algorithm. Only after you know for sure that no one
ever devised a faster way of doing what you want to do, then go and add
CPU-specific optimizations. Measure what parts of your programs are too
slow and optimize only those. Anything else is a waste of your precious
programmer time.
By the way, many micro-optimizations are the same across CPU types, so
if you take a program written on a different CPU, it will perform quite
similar. The remaining difference isn't worth your time (again, unless
you measured it to be too slow for your use case)
Another side note: Compilers actually are able to perform many
micro-optimizations automatically, including converting an up-counting
loop to a down-counting one. In what cases and on which CPU this is
supported is highly compiler- and version-dependent, however.
von IA (Guest)
Thanks Sam for your reply - Fair enough!
von Christian B. (casandro)
Felix von Leitner (aka. Fefe) has given a nice talk on the problem.
ftp://media.ccc.de/events/camp2007/video/m4v/cccamp07-en-1952-Know_your_
compiler.m4v
von (prx) A. K. (prx)
I have not seen any significant pressure to optimize this. In part
because people know to avoid this (yes, this is a self referential
argument) and in part because passing structures by reference is a lot
more efficient and likely will be for some time. I'd guess that until
someone implements a copy-of-write mechanism for this, it won't change
soon.
The function call mechanism is defined by the ABI. This usually is a
long term definition, not to be easily changed by some compiler author.
While it sometimes happens, not count on ABI changes in the lifetime of
a given architecture. This more likely happens when a new architecture
is introduced, or an existing architecture changes significantly.
GCC already does this for ages.
Generally not, not unless you claim maximum achievable performance
instead of acceptable performance. Not in case of those architectures.
Things are somewhat different when we refer to 8-Bit processors like
PIC, 8051 and AVR though, since these often have deficiencies
implementing certain C language elements and concepts.
There are limits. When the absolute maximum speed is to be achieved and
the original code was sort of hand tuned by looking at the code
generated, it may still require some hand tuning for a different
machine. Compilers are not perfect.
Also there are effects out of the compilers scope which have to be
considered when writing efficient code and the details to optimize for
can be different on different machines, even those sharing the same
fundamental architecture. An example is closely coupled multiprocessing,
which has to account for dirty stuff like cache line sizes and coherency
mechanisms.
von Oliver (Guest)
If you can find a meaningfull definition of "efficiently", which
considers the platform differences between a 4Ghz Quadcore x86 and a
single core 500Mhz (or so) ARM, then no.
In case that you have hand-optimized inline Assembler for the x86
platform, well, I would consider to stay with the x86...
Oliver
While the top ARM implementations are not even remotely within range of
top Intel chips, especially with regard to single thread performance and
overall throughput, things are different in the mobile world, where the
various quad core ARMs are roughly comparable to Intel's Atom products.
von Hmm (Guest)
Sam P. and especially A.K. (with unproncouncable nick "prx" :-)) had
some important points which I agree with.
I must confess, that, while thinking about your (and A.K.s arguments, I
found some proposals which I would seriously decline, some I have doubts
about having positive impacts (like collection parameters into
structures and) and some I find unconvinient (like loop sequence
reversal) and I wonder how "any" optimization makes sense at all. :-)
For example: I (myself) missed a certain point which I consider
relatively important. That is: I prefer what I (literally) wrote above
what might be more efficient.
This is relevant in two cases you mentioned:
Reverse loop order would also reverse the sequence of operation. In case
I rely on a "sideeffect", which could be accessing registers in a
certain order (as with some registers of the AVRs) I desparately don't
want the compiler to "optimize" because that would lead to a defective
behavior.
The same is relevant in case of passing structures and the optimization
you mentioned by reorder of the members. In case I communicate those
structures I even do not wish that the compiler reorders them. (This
point conflicts with the definition that in C one may rely in no respect
to any particular order of the members. But this is usual to an extent
which makes it relevant in my opinion).
Optimzation is not a "silver bullet". Its just a tool with its quirks.
It is advisable to see optimization as something with two faces (like
Jekyll and Hyde). It may help but it may also be evil.
Additionally one may (as me) experience practical issues with certain
compilers (I prefer to switch of optimisatons on IAR for the STM-ARMS).
And furthermore I found that many (partly very experienced programmers
like Karl Heinz, which you may meet quite often here) who state, that a
program must function as well with and without optmizations. I myself
did that too. But this is merely a hint for a beginner. An experienced
programmer shall (my opinion) consider this more a rule of thumb instead
of a general rule. It may give hints when optimization affects the
programs behavior but it is not negative by itself.
But to come back to your question: I think it is a bit dispropionate to
consider the degree by which compilers optimized in 2000 as "incomplete"
or unsophisticated in comparison to todays optimizers. It may be true
for some minor, very specific issues but not in general.
Very interesting discussion. Good night. :-)
Reversing the counter does not necessarily reverse the order of
operations, as this would be a bit too agressive. If you look at GCC's
loop optimizations, you may occasionally find a loop counter which
looses its role as array index.
Example:
        for (i = k; i < n; ++i)
                g(a[i]);
may translate into
.L3:
        ldr     r0, [r5, #4]!
        bl      g
        add     r4, r4, #1
        cmp     r4, r6
        bne     .L3
where the loop counter (r4) is disconnected from its role as array index
because an incremented pointer register (r5) is used instead. In this
code, r4 is therefore free to count from n-k downward to 0 like in
.L3:
        ldr     r0, [r5, #4]!
        bl      g
        subs    r4, r4, #1
        bne     .L3
Note that optimizations roughly like these may also help in a more
subtle but sometimes very effective way when the implementation uses
deep out of order processing instead of a simple Cortex-M pipeline,
because they separate data and control flows which could otherwise be
linked creating unneccessary dependencies.
von Hmm (Guest)
>Reversing the counter does not necessarily reverse the order of operations, ...
I see. That's a point, A.K.!
Should have another look again at gcc source.
von IA (Guest)
Thanks Christian, but the video does not play. I get a still image with
the title of the talk, and there is no audio. Was anybody able to play
the video?
von IA (Guest)
Thanks A. K. for your detailed reply!
von IA (Guest)
Thanks Oliver... I agree with A. K. on his reply to you
von IA (Guest)
> I prefer what I (literally) wrote above what might be more efficient.
Agree... Readability of source code seems to be more important than
low-level optimization as compilers are smart enough nowadays
> behavior.
Besides the example that A.K. has shown, there are some cases where you
may even need to re-write the loop by incrementing the pointer rather
than using an index (i.e. avoid using a[i]). This enables generating
more efficient code by leveraging the post-increment addressing mode of
ARM load/store instructions (hence saving the increment instruction).
I invite you to take a look at the book that I have mentioned in my
original post. It has many of such tricks that I have tried myself. I
have to admit that many of them have shown to be useless with setting
the compiler to a high-level of optimization, but it is sometimes worth
knowing what tricks the compiler may do.
> a program must function as well with and without optmizations
Sure, functionality should be guaranteed. Optimizations may just reduce
memory footprint/bandwidth, and increase throughput
von IA (Guest)
All,
After this fruitful discussion, I would come to the conclusion, that I'd
better focus on the algorithm, where there is higher potential for
performance improvement. It is still a plus to know how to optimize the
source code at the low level. This may help in cases where a piece of
code is detected to be a bottleneck, and low-level optimizing it becomes
a requirement.
I confess that I have always been a passive participant in forums (I
refer a lot to forums, but I almost never posted in any). I enjoyed the
fact that I could open a discussion with a bunch of experts, and get
educated as well as contribute to others. I should do that more often ;)
Thank you, and all the best!
von IA (Guest)
Christian, I was able to play the video with VLC. Media player was not
playing the audio. Will watch it some time soon. Thanks!
> more efficient code
Or less efficient code, depending on the implementation of the
processor. If the increment operation is part of the load operation, it
forces loads in successive iterations depend on each other, whereas they
are independant if indexed addressing is used. Could make a significant
difference for an out of order core.
This is exactly one of those optimizations, which may turn out to be
de-optimizations when you want to run the code on a different machine
later, maybe even within the same basic architecture.
With todays compilers, better use indexed operations in C and leave
those kind of optimizations to the compiler, which is (hopefully)
designed to optimize for the actual target hardware and avoids some
pitfalls. The example above shows, that GCC already does optimize the
way you would have done by hand, while it does not for x86, which does
not have an autoincrement address mode but a cheap scaled index instead.
von IA (Guest)
A.K.,
> Reply
That is the conclusion that I have reached. The chances that the
compiler will do the job are high enough to prevent me from spending my
time focusing on such HW-related low-level optimization details. If, I
happen to fall into a situation where a piece of code is acting as a
bottleneck, and it has to be optimized, I may need to optimize its
source code (based on my knowledge of the HW core), as a step before
thinking of writing it in Assembly.
