Forum: FPGA, VHDL & Verilog help with 4 bit 2 to 1 MUX
von mike m. (mikulski)
Ok I neex to make a 4 bit MUX using structural VHDL and I'm not sure if
I set it up correctly. I'm either mixing up how to correctly test the 4
bit MUX using a test bench waveform or I'm assigning the Select
incorrectly. I tested the 1 bit MUX and it worked fine.
Attached are images of my code
Do you want to get a 4-bit 2-to-1 mux (with 4 inputs, 1 select and 4
outputs), or do you want a single 4-to-1 mux (4 in, 2 select,1 out)?
BTW: do you program VHDL with pictures? No? So, why do you not simply
attach the *.vhd files?
Sorry I have already solved that problem. I was using my pre-edited code
haha. However, I receive errors when I synthesize my flip flop. I get
errors stating:
WARNING:Xst:2170 - Unit MMFlipFlop : the following signal(s) form a
combinatorial loop: Q.
combinatorial loop: M1.
Am I supposed to be receiving these combinatorial loop warnings? The
flip flop performed correctly when I did test bench tests. I figure
since I am doing structural VHDL, I should have 0 errors in order to
avoid problems down the road. Attached are the VHDL files and a picture
of my diagram.
And how?
(Just for information, if someone else needs help in fututre times...)
> errors stating:
These are no ERRORS but just simple WARNINGS. Thats a major difference!
This messages come from your latches. A latch consists mainly of a
combinatorial loop from the Output to the input. But usually such loops
are made unintenionally, and so the synthesizer warns...
> The flip flop performed correctly when I did test bench tests. I figure
You get this error because you are doing structural VDHL. Everyone
else on the world would write something like this to get a D-FF:
process (ck) begin
  if rising_edge(ck) then
     q <= d;
  end if;
end process;
With this the synthesizer immediatelly knows which component to use...
With your structural description the synthesizer tries to build a D-FF
out of a bunch of LUTs, not being able to recognize that there are
thousands of components laying around doing exactly what you want deep
inside.
As I already said: tell your teacher its a fairly stupid job waisting
time with a VHDL description style from the last millenium. The tools do
not expect such an old-fashioned coding style and they will produce
inefficient results. Why learning such things?
> And how?
> (Just for information, if someone else needs help in future times...)
Well it turns out that I didn't add the a gate for the inverter in the 2
to 1 MUX. Also in my 4 bit 2 to 1 MUX I should have had:
gate1  :  mm2to1MUX  PORT MAP(D0=>'0',D1=>D1(3),S=>S,Z=>Z(3));
gate2  :  mm2to1MUX  PORT MAP(D0=>'0',D1=>D1(2),S=>S,Z=>Z(2));
gate3  :  mm2to1MUX  PORT MAP(D0=>'0',D1=>D1(1),S=>S,Z=>Z(1));
gate4  :  mm2to1MUX  PORT MAP(D0=>'0',D1=>D1(0),S=>S,Z=>Z(0));
I figured as much thanks for the info! This warning doesn't give me any
irregular ouputs so this shouldn't cause any errors in other components
when I use this 4 bit 2 to 1 MUX?
I couldn't agree with you more! However, he will not use behavioral VHDL
as he believes the class will get a better understanding by doing
components individually and understanding how everything connects to
each other.
I'm trying to connect the 6 bit MUX(Ijust incremented it from 4 to 6) D0
signal to ground(0). However when I try and do so I get a bunch of
warnings:
WARNING:Xst:647 - Input <D0> is never used.
Unit <mm6bitMUX> synthesized.
WARNING:Xst:1290 - Hierarchical block <gate1> is unconnected in block <gate1>.
   It will be removed from the design.
WARNING:Xst:1290 - Hierarchical block <gate2> is unconnected in block <gate1>.
WARNING:Xst:1290 - Hierarchical block <gate1> is unconnected in block <gate2>.
WARNING:Xst:1290 - Hierarchical block <gate2> is unconnected in block <gate2>.
WARNING:Xst:1290 - Hierarchical block <gate1> is unconnected in block <gate3>.
WARNING:Xst:1290 - Hierarchical block <gate2> is unconnected in block <gate3>.
WARNING:Xst:1290 - Hierarchical block <gate1> is unconnected in block <gate4>.
WARNING:Xst:1290 - Hierarchical block <gate2> is unconnected in block <gate4>.
WARNING:Xst:1290 - Hierarchical block <gate1> is unconnected in block <gate5>.
WARNING:Xst:1290 - Hierarchical block <gate2> is unconnected in block <gate5>.
WARNING:Xst:1290 - Hierarchical block <gate1> is unconnected in block <gate6>.
WARNING:Xst:1290 - Hierarchical block <gate2> is unconnected in block <gate6>.
What would the correct way to connect an input to ground? Attached is
the overall program counter diagram that I need to make. As you can see
D0 would be connected to '0' and D1 would be the output signal coming
from the adder.
> warnings:
You are doing it the correct way, and the toolchain correctly recognizes
that it is not necessary to implement a static-'0' path in the mux. So
this path is optimised away.
To sum it up: thats the information I give my trainees, and thats the
information your teacher should give you. To bad that he doesn't...
