Forum: ARM programming with GCC/GNU tools confused by "typedef enum"
von cprog (Guest)
I'm integrating a C library into my C project and have run across
compile issues that have left me thoroughly confused.
First we have this in a header file (keep in mind I've changed the
variable names):
typedef enum
    ITEM1,
    ITEM2,
    ITEM3,
    ITEM4,
    ITEM5
} MyError;
Then in a source file:
typedef MyError( *send_pdu ) ( unsigned int8  adr,
const unsigned int8 * pdu, unsigned int16 len );
I'm really confused as to the "typedef enum".  I know what typedef does,
and I know what enum does.  What is the second statement doing?
von gjlayde (Guest)
The second typedef defines a function type like this:
MyError func (unsigned int8, const unsigned int8*, unsigned int16);
Your typed are odd.
You really really should switch to C99's stdint.h and use uint8_t et al.
von cprog (Guest)
Ok great, thank you.  That clears things up.
This is an 8-bit PIC compiler so I would expect some weirdness.
