Forum: µC & Digital Electronics problem with reading external ADC values.
Author: vema (Guest)
I have started newly working with AVR microcontroller.I am using
ATmega32-A microcontroller. I have connected one external ADC(AD7798). I
want read external ADC values using SPI communication.I have tried so
much but i am not able to get ADC values. My project is I have to
generate waveform using micro controller with programmable waveform
generator. I am successfully doing this and giving this signal to
sensor. I want read sensor output given to ADC and trying to read adc
value. I have attached simple circuit diagram below. I wrote code like
this
    // I have initialized PORTB like this
    PORTB=0x00;
    DDRB=0xBF;
    // SPI initialisation
    // SPI clock rate fck/16
    // SPI master
    // SPI MSB first
    // SPI CPOL = 1, CPHA = 1
    SPCR=0x5D;
    PORTB.3 = 1;
    void main (void){
     printf("adc value :%x\n",ReadAd());
I wrote all function in another file
    #define ADC_CS PORTB.3
    #define WG_CS PORTB.4
    #define MOSI PORTB.5
    #define MISO PINB.6
    #define SCK PORTB.7
    #define ADC_CS_PIN PINB.3
    #define WG_CS_PIN PINB.4
    char spi(char data)
    //Start transmision
    SPDR = data;
    //Wait for transmision complete
    while(!(SPSR & 0x80));
    return SPDR;
    //Sets the waveform generator output to given phase
    void SetWGPhase(unsigned int phase)
    SPCR = 0x5A;
    WG_CS = 0;
    while(WG_CS_PIN);
    spi(0x20);
    spi(0x00);
    spi((char)((phase>>8)|0xC0));     //Load into phase register 0
    spi((char)(phase & 0x00FF));
    WG_CS = 1;
    unsigned int ReadAd(void)
    unsigned int data;
     ChipSelectAd(1);
    //Read data
    CheckStatus();         //Wait for data ready in
                             adc register
    spi(0x58);              //Place readinstruction
                            in communication register
    data = (spi(0xFF)<<8);    //Read 8 most significant
                             bits from data register
    data |= spi(0xFF);      //Read 8 leastsignificant
    return data;
    ChipSelectAd(0);
    void CheckStatus(void)
    char adcStatus;
    do
    (void) spi(0x40);
    adcStatus = spi(0xFF);
    } while((adcStatus & 0x80) > 0);
    void ChipSelectAd(char s)
    if(s == 1){
        PORTB.3 = 0;    //Switch on AD
        while(PINB.3);  //Wait for chip select pin
        else
            PORTB.3 = 1;    //Switch of AD
I have read data sheet hundreds of times but still I am able to read ADC
value. I am confusing what mistakes I am doing. I have checked each and
every pin and I have checked ADC input pin using Oscilloscope, i am
getting 0.6V input signal. Please help me to solve this problem.
Tommarow is the deadline for this project. Please any one help me to
read ADC values.
Thanks in advance.
