Forum: ARM programming with GCC/GNU tools launchpad gcc for ARM: Understanding linker scripts
von Lauren (Guest)
Greetings to all,
I want to run code from a ram-location on a STM32F407 (Cortex-M4)
microcontroller, but before I can do this, I want to understand the
linker-commands, and this seems to be a real challenge.
At first, I want to find out where some code-fragments to run from ram
later are located.
I'm using Coocox in combined with launchpad-gcc-toolchain and modified
the default-linker-script:
SECTIONS
    .text 0x08000000:
     bootstart = ABSOLUTE(.) ;
     KEEP(*(.isr_vector .isr_vector.*))
     bootend = ABSOLUTE(.)  ;
     *(.text .text.* .gnu.linkonce.t.*)
     *(.glue_7t) *(.glue_7)
     *(.rodata .rodata* .gnu.linkonce.r.*)
I inserted the assigment of the vars "bootstart" and "bootend" and hoped
to see where the isr_vector-section begins and where it ends.
Regarding to the documentation of the linker I should get
"bootstart = 0x08000000" and "bootend = 0x080001ff".
But even these simple assigments don't work, I got "bootstart =
0x20000804" and "bootend = 0xaf00b580", superfluouses to mention, that
the STM doesn't have so much memory.
SECTIONS
 . = 0x08000000;
 bootstart = . ;
    .text :
It's amazing, that the code generated with these linker-scripts is still
executeable on my discovery-board...
Can someone please tell me, what's going (wr)on(g) here?
Lauren
von Martin Thomas (Guest)
You may start with a linker-script template for the GNU linker that
comes with the ST StdPerLib or the template given in the readme-file of
the "launchpad" package. The default linker-script shown by
arm-none-eabi-ld --verbose does not fit well for systems with
non-continues memory-regions for read-only (Flash) and read/write (RAM).
Just a remark: The entry KEEP(*(.isr_vector .isr_vector.*)) is not the
best idea. There should be exactly one input-section with the vector
table since this must be located a the correct location, so the
controller finds initial stack-pointer and start-address.
Just to get an idea a few lines from the linker-script I'm currently
using which is based on the one from the StdPerLib-Template for
TrueStudio:
ENTRY(Reset_Handler)
MEMORY
  FLASH (rx)      : ORIGIN = 0x08000000, LENGTH = 1024K
  RAM (xrw)       : ORIGIN = 0x20000000, LENGTH = 112K
SECTIONS
  .text :
    ___SVECTOR = .;
    KEEP(*(.isr_vector)) /* Startup code */
    ASSERT (. != ___SVECTOR, "No isr_vector input-section!");
    . = ALIGN(4);
    *(.text)
    *(.text.*)
    *(.gnu.linkonce.t.*)
    [... removed ...]
  } >FLASH
  [... arm.extab, arm.exidx, data and bss defintions here ...]
