Forum: ARM programming with GCC/GNU tools sam9g45 SPI problem
Author: Roman Bel (Guest)
Dear Mr,
I have problem with SPI interface on SAM9G45.  Osciloscope is connected
to MOSI, SCK, CS wire. I set SPI interface to 8bit mode, master mode. If
I send 8bit word to TDR(transmit data register), I see on scope always
previous 8bit word. I try to write this problem on example:
1.     while ((*AT91C_SPI0_SR & AT91C_SPI_TXEMPTY) == 0){};
2.    *AT91C_SPI0_TDR=0xF1;
3.    while ((*AT91C_SPI0_SR & AT91C_SPI_TXEMPTY) == 0){};
4.    *AT91C_SPI0_TDR=0x01;
At note 1. im waiting for clear transmit buffer
At note 2. im  transmiting number 0xF1
At note 3. im waiting for clear transmit buffer
At note 4. im transmiting number 0x01. I see on my osciloscope that
number is not 0x01 but 0xF1!!! Transmit function, as I know from Atmega
chips and AVR32 chips, would transmit 0x01.
I think setting of SPI interface is good. But where is the problem?
All setting code is here:
void spi_init(void)
      uint32_t baudrate;
      *AT91C_PMC_PCER= SPI0_PERIPH_ID; //clock for spi0 enabled
      *AT91C_SPI0_CR=AT91C_SPI_SPIDIS;
      *AT91C_SPI0_CR=AT91C_SPI_SWRST;  //reset
*AT91C_SPI0_MR=AT91C_SPI_MSTR | AT91C_SPI_MODFDIS;//master mode, disable
fault detection
      baudrate = BOARD_MCK/1000000;//1Mbit
      *AT91C_SPI0_CSR=AT91C_SPI_BITS_8 | AT91C_SPI_CPOL |
AT91C_SPI_NCPHA | ((baudrate&0xFF)<<8) |AT91C_SPI_DLYBS;//|
AT91C_SPI_CSAAT;
      //AT91C_SPI0_SR
      //AT91C_SPI0_RDR
      *AT91C_SPI0_CR=AT91C_SPI_SPIEN;
Thank you, RB
