hi I'm trying to write code for SDI-12 protocol the byte frame format of SDI-12 is 1 start bit 7 data bits, least significant bit transmitted first 1 parity bit, even parity 1 stop bit I want to transmit an 24 bits of data i.e., 100001101011001010000100 which when arranged in frame looks like start,1000011,P,stop, start,0101100,P,stop, start,1010000,P,stop, start,100_ _ ,P,stop P->parity bit the problem is what data should I transmit in the last for bits i.e.,_ _ how should i know that the data to be sent is completed. help me with any protocol to get an idea about (how should i know that the data to be sent is completed.) I'm attaching the code I've written help me CODE: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; entity serialtx is generic (data_width : integer); port ( clk,reset :in std_logic; tx_data : in std_logic_vector(data_width-1 downto 0); tx_out : out std_logic ); end serialtx; ARCHITECTURE behavioral of serialtx is type ofstate is (IDLE, START_bit, STOP_bit); signal state, nextstate : ofstate; signal parity_bit,tx_enable : std_logic; begin process variable count,p_val : integer:=0; begin if(clk'event and clk='1' and tx_enable='1')then if(reset='1')then tx_out<='0'; else case state is when IDLE => tx_out<='0'; nextstate<=START_bit; when START_bit=> count:=count+1; if(count>=0 and count<7)then for b in p_val to data_width-1 loop tx_out<=tx_data(p_val); end loop; elsif(count=7)then tx_out<=parity_bit; p_val:=p_val+1; elsif(count=8 )then tx_out<='1'; nextstate<=STOP_bit; count:=0; end if; when STOP_bit=> --if--data to be sent is completed then tx_out<='1'; tx_enable<='0'; --else nextstate<=IDLE; --end if; end case; end if; end if; end process; end behavioral;
