Forum: ARM programming with GCC/GNU tools arm-elf-ld problem, undefined reference to `__gccmain'
von (unknown) (Guest)
Hello, I have problems when I am trying to link together a project
example which I found on the net (I have attached the important files,
just type make main.elf in the terminal).
When the following command is executed:
arm-elf-ld -v -lc -Map main.map -nostartfiles -T ld_flash.cmd -o
main.elf crt.o main.o
I get this error message:
main.o(.text+0x1e4): In function `main':
home.../main.c:153: undefined reference to `__gccmain'
I suppose it is some library problem and I have tried a lot of different
ways of including libc.a, but still I have not got it to work?
/Dan
von skriptkiddy (Guest)
I successfully build the project using Codesourcery ARM 2011.03.
von Rolf Magnus (Guest)
__gccmain is in libgcc, not in libc.
Thank you for the replies.
@ Rolf Magnus, I have tired libgcc as well. When I run the command using
libgcc:
arm-elf-ld -v -g -O0 -T ld_flash.cmd -o main.elf crt.o main.o
-L/usr/local/lib/gcc-lib/arm-elf/2.95.3 -L/usr/local/arm-elf/lib/ -lgcc
I get the following error message:
/usr/local/lib/gcc-lib/arm-elf/2.95.3/libgcc.a(__main.o)(.text+0xbc): In
function `__do_global_ctors':
: undefined reference to `atexit'
/usr/local/lib/gcc-lib/arm-elf/2.95.3/libgcc.a(__main.o)(.text+0xc4): In
: undefined reference to `__CTOR_LIST__'
/usr/local/lib/gcc-lib/arm-elf/2.95.3/libgcc.a(__main.o)(.data+0x0):
undefined reference to `__DTOR_LIST__'
When I run the command with libc:
-L/usr/local/lib/gcc-lib/arm-elf/2.95.3 -L/usr/local/arm-elf/lib/ -lc
I get:
main.o(.text+0x1e0): In function `main':
home.../ArmPrj/main.c:153: undefined reference to `__gccmain'
@ skriptkiddy, Nice to hear, if I don't get this to work I will also try
Codesourcery ARM 2011.03. Could you please run:
arm-elf-gcc -S main.c -o main.s
and attach the assembler file here. I have detected a strange line in my
assembler file:
bl __gccmain
Which stands for branch to the label __gccmain, but there isn't any
label named __gccmain and I can't see the reason why there is a branch
there at all.
/Dan
I found the solution at:
http://www.embedinfo.com/en/FAQ/FAQanswer.asp?id=19
The problem could simply be solved by changing the name of int main() to
int _gccmain().
/Dan
von Name: (Guest)
Usually it´s better to use the gcc command also for linking as it takes
care for the correct libs, unlike the ld command which requires the libs
to be specified explicitely.
Do you mean the arm-elf-gcc instead of the arm-elf-ld command? I still
get an error when I am running:
arm-elf-gcc -v -g -O0 -T ld_flash.cmd -o main.elf crt.o main.o
The output is:
/usr/local/lib/gcc-lib/arm-elf/2.95.3/collect2 -X -o main.elf
/usr/local/arm-elf/lib/crt0.o -L/usr/local/lib/gcc-lib/arm-elf/2.95.3
-L/usr/local/arm-elf/lib crt.o main.o -lgcc -lg -lc -lgcc -T
ld_flash.cmd
/usr/local/arm-elf/bin/ld.real: warning: no memory region specified for
section `.note.ABI-tag'
/usr/local/arm-elf/bin/ld.real: section .note.ABI-tag [00000000 ->
0000001f] overlaps section .text [00000000 -> 00001e3b]
/Dan
