Forum: FPGA, VHDL & Verilog Vim plugin for verilog instance generation, highly recommended!
von ming z. (Company: none) (zhangwenming)
This script is used for automatically generating verilog instance from
the file. When you type the given hot-key, instance will be copied to
system clipboard, and display or not by  its working mode. Once your
file can access syntax check, this plunin will work, or there must be a
bug. It's encouraged to share it with me and all other people.
Supported working mode:
    mode 0(default):
        copy inst to clipboard and echo inst in commandline
    mode 1:
        only copy to clipboard
    mode 2:
        copy to clipboard and echo inst in split window
    mode 3:
        copy to clipboard and update inst_comment to file
  To change the default working mode, you should modify the line "let
g:vlog_inst_gen_mode=x", x is the default working mode.
User defined command:
        VlogInstGen : generate verilog instance
        VlogInstMod : change working mode
Default hot-keys:
        ,ig         : VlogInstGen
        ,im        : VlogInstMod
Newest version from:
http://www.vim.org/scripts/script.php?script_id=4151
