Forum: FPGA, VHDL & Verilog Problem in real-time data acqusition using Zest Et1
von John (Guest)
Hi everybody.
I am using ZESTET1 module, which implements 1G Ethernet.
I was able to properly use this module and could send data to PC up to
110 MByte/s.
However, in my application I need to receive real-time data with 70
MByte/s data rate.
At this speed and real-time application, when I run the software CPU
usage of my PC dramatically goes high and any event in my PC such as
clicking on my software causes loosing data.
I use socket programming for read/write data from LAN port in PC. I
checked size of data which PC OS (windows) issues event for me and its
maximum size is 8 Kbyte.
I found that this is my problem. Due to the small size of provided data
by windows, my software has to check the socket and read data;
consequently, PC CPU is dramatically concerned with my software and CPU
usage goes high.
Do you have any idea what I can do for solving this problem?
Thank you in advance.
von Behfar (Guest)
You need to write a device driver to read it real time.
Download the latest DDK from microsoft and see its sample source codes
for network.
