Forum: FPGA, VHDL & Verilog / operand can not have such operands in this context
von dhootha a. (Company: Student) (gollum)
I am using the following libraries
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use ieee.numeric_std.all;
library ieee_proposed;
use ieee_proposed.fixed_float_types.all;
use ieee_proposed.fixed_pkg.all;
I get this error"/ cannot have such operands in this context" at line
where variable c is assigned in the following code when i checked the
syntax
I have got this error at all places where the / operator is used in
fixed point operations.
type comp is
  record
    Rel :sfixed(7 downto -6);
    Img :sfixed(7 downto -6);
  end record;
function complexdiv(seven :comp; h :sfixed(7 downto -6)) return comp is
variable result5 :comp;
variable a,b,c,d :sfixed(14 downto -13) ;
begin
  c :=seven.Rel / h;
  --result5.Rel := resize(d,result5.Rel) ;
  --result5.Img := resize(seven.Img/h,result5.Img) ;
return result5;
end complexdiv;
What might be the problem??
dhootha adhi wrote:
> I get this error "/ cannot have such operands in this context"
From who: simulator or synthesizer? Which one?
synthesizer
Division is not synthesizable!
Ok, it is synthesizable if the divisor is a constant and a power of 2.
Your h is none of them...
okay.Thanks a lot
