Forum: µC & Digital Electronics lpc2388 interrupt problem
von Kevin T. (Company: TCS) (kft)
I have a problem with interrupts on the lpc2388.  The processor enters
the interrupt mode and then hangs.  I have tried fiq and irq modes, with
the same results.  As a diagnostic, I placed a U0THR='I'; as the first
instruction in both my interrupt routine and in the stubs, which I have
tried enabled, and commented out.  The instruction is never executed.
My initialization code is as follows:
  VICVectAddr=0;
 //  VICIntSelect = 1<<28;      // uart2 int is fiq
   VICSoftIntClr = 0xffffffff;
  VICVectAddr28 = (unsigned)(void*)uart2_isr;
  VICVectCntl28 = 1;
  VICIntEnable = 1<<28;
I am using gcc - latest yagarto build.  Any assistance would be much
appreciated.
Thanks
Kevin Twiggs
von Microman (Guest)
Hi Kevin,
have you enabled the global IRQ or FIQ in the CPSR core register of the
LPC? Without that, the core will never recognize any action from the
off-core VIC hardware. Try this to to so:
void enable_irq (void)
  _asm__ __volatile_ ("MRS r1, CPSR");
  _asm__ __volatile_ ("BIC r1, r1, #0x80");
  _asm__ __volatile_ ("MSR CPSR_c, r1");
void AVIC_enable_fiq (void)
  _asm__ __volatile_ ("BIC r1, r1, #0x40");
Best Microman
Hi
Yes I have, the problem is that the interrupt happens, and I dont know
what it is calling, because it never reaches my diagnostics.  There are
stubs in the startup code for IRQ,FIQ etc, do I need to link to them, ot
how does GCC put its vector in place?
I had a similar scheme working on a lpc2103, the difference was that the
2103 has a default irq vector register, and I think this the problem
that I have with the 2388, there is a link missing.
Thanks
Kevin Twiggs
von Martin Thomas (Guest)
Please create a minimal example to reproduce the issue (source-code
incl. startup, linker-script, makefile or at least all compiler,
assembler and linker options. Note the difference between VIC190 as in
LPC2103 and VIC192 as in LPC23xx. IRC there is an application-note on
porting between "old" and "new" LPC2xxx available on nxp.com.
Hi
I have attached a zip file with all the source code in it.
Thanks
Kevin Twiggs
Just a quick remark since I currently do not have enough time to take a
closer look into the code.
If the ISR is emplemented with the ISR_ENTRY/ISR_EXIT-Macros the naked
attribut has to be used so at least change
//void uart2_isr (void) _attribute_ ((naked));
void uart2_isr (void) _attribute_ ((interrupt("IRQ")));
to
//void uart2_isr (void) _attribute_ ((interrupt("IRQ")));
Background: when using attribut IRQ and Macros the return-address from
the ISR will be "adjusted" twice which is wrong (see
disassembly/lss-file: first "adjust" caused by macro:
19c:  e24ee004   sub  lr, lr, #4
second "adjust" inserted by compiler b/o attribute IRQ
1f0:  e25ef004   subs  pc, lr, #4
Maybe this rather old example code helps a little bit:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/#lpc23xx_demo1
You may also take a look into ChaN's (elm-chan.org) FatFs-examples.
There is one example for LPC23xx with interrupt-driven UART which uses a
very different approach (Assembler-Wrapper for IRQs, no macros, no
attributes, ISRs are implemented as "plain" C-functions which are called
by the ASM-wrapper which is called by the core on IRQ-exceptions).
