Using Digilent Nexys 2 board which has a rs232 port (uses the Spartan 3E
fpga).
Trying to test the rs232, i have a usb to rs232 cable and i use Putty
which all seems to be working ok. So i wrote this for the FPGA to loop
back RX and TX so the fpga would just echo back what ever data it got.
1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 |
4 | entity top is
5 | Port ( rxd : in STD_LOGIC;
6 | txd : out STD_LOGIC);
7 | end top;
8 |
9 | architecture Behavioral of top is
10 |
11 | begin
12 |
13 | txd <= rxd;
14 |
15 | end Behavioral;
Unfortunately once put on the fpga i can't write anything in the
terminal which i think is because the fpga is not echoing back the data.
Can anyone see the problem here? Or have a better way to test the rs232?
Thanks.
