Hi all! I am trying to make a 4 bit ALU. Here is a sample entity declaration: entity myALU is Port ( Opcode : in STD_LOGIC_VECTOR (2 downto 0); Ain, Bin : in STD_LOGIC_VECTOR (3 downto 0); --Operand 1 and 2 Cin : in STD_LOGIC; -- carry in Output : out STD_LOGIC_VECTOR (3 downto 0); Zero : out STD_LOGIC; Co : out STD_LOGIC ); end myALU; The ALU should perform the following operations according to the Opcode: Opcode | Operation | Output | Carry Out(Co) | 000 | NOP | A | 0 001 | AND | A & B | 0 010 | OR | A or B | 0 011 | XOR | A xor B | 0 100 | ADD | A + B |'1' if (A + B) > $F, else '0' 101 | ADC | A+B+Cin |'1' if (A + B + Cin) > $F else '0' 110 | SUB | |A - B| |'1' if (A < B), else '0' 111 | SBC | |Cin + A-B| |'1' if (A + Cin) < B, else '0' [Zero <= '1' if Output is 0, else '0'] Can someone please help me write a VHDL code for that ALU, You can find attached the code that I have written but it doesn't work and I am consfused. Thank you.
At least the sensitivity-list is incomplete. The simulator will not show the real behaviour. greetings
I do not find a clock. At this stage you should write a testbench, where you put some input signals into the ALU and look what happens.
Can you please also post your testbench code? Maybe there is the error?
peres Z. wrote: > I did it but I have wrong values WHAT values? For help you MUST provide as much information as possible. Who do you think can help when you say: "My car doesn't run! Whats wrong with it?" And think again about this what Daniel M. wrote: >> At least the sensitivity-list is incomplete. Z, Cin and Cx is missing! And because of the missing Z you will see some very very strange bahviour...
