Forum: FPGA, VHDL & Verilog numeric_std, std_logic_vector to integer
von A. S. (aleksazr)
code snipets:
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity TEST is port (
    addr : in integer range 0 to 31;
end TEST;
component TEST port (
end component;
DBUS : inout std_logic_vector(15 downto 0);
Inst_TEST: TEST port map (
    addr => to_integer(unsigned(DBUS(4 downto 0))),
This is where I get the ISE error:
Actual, ParameterAssocOp, associated with
Formal Signal, Signal 'addr', is not a Signal. (LRM 2.1.1)
What am I doing wrong here?
von P. K. (pek)
Mapping "inout" to "in" port?
Try it with a local signal:
addrhelp : integer range 0 to 31;
addrhelp <= to_integer(unsigned(DBUS(4 downto 0)));
    addr => addrhelp
In this way no function or procedure is called within the port
assignment...
No, that wasn't the problem...
And what was the problem?
> assignment...
Thats it, thanks.
"You can't put the conversion right in the port mapping."
http://forums.xilinx.com/t5/Synthesis/numeric-std-std-logic-vector-to-integer/td-p/245590
I intended to reply to both you and Peter
at the same time, but got interrupted in between.
