Forum: ARM programming with GCC/GNU tools ARM linker fail
von bogdanul2003 (Guest)
I'm trying to compile RTEMS for a STM32F4DISCOVERY board. Everything
goes well until the linker tries to find the linker script
linkcmds.armv7m. I searched for the file on my system and I found it
some places.
/opt/rtems-4.11/bin/ld/linkcmds.armv7m
/opt/rtems-4.11/arm-rtemseabi4.11/lib/linkcmds.armv7m
find: `/home/boil/.gvfs': Permission denied
/home/boil/Documents/b-rtems/arm-rtemseabi4.11/gumstix/lib/linkcmds.armv
7m
/home/boil/Documents/arm-work/rtos/c/src/lib/libbsp/arm/shared/startup/l
inkcmds.armv7m
/home/boil/Documents/arm-work/base_sp2/linkcmds.armv7m
/home/boil/Documents/arm-work/lib/linkcmds.armv7m
/home/boil/Documents/arm-work/bin/arm-rtemseabi4.11/stm32f4/lib/linkcmds
.armv7m
/home/boil/Documents/rtems/c/src/lib/libbsp/arm/shared/startup/linkcmds.
armv7m
And this is the last output when trying to comppile RTEMS
arm-rtemseabi4.11-gcc -Os -B ./../bin/arm-rtemseabi4.11/stm32f4/lib/
-specs bsp_specs -qrtems -mstructure-size-boundary=8 -march=armv7-m
-mthumb -fno-schedule-insns2 -fno-common -O0 -g3 -ggdb -g -Wall
-Wmissing-prototypes -Wimplicit-function-declaration
-mstructure-size-boundary=8 -march=armv7-m -mthumb -fno-schedule-insns2
-fno-common -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
-DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_STRINGS_H=1
-DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_CSTDIO=1
-DHAVE_CSTDLIB=1 -DHAVE_IOSTREAM=1
-I./../bin/arm-rtemseabi4.11/stm32f4/lib/include -I./inc  -g
-Wstrict-prototypes -Wnested-externs ./obj/stm32f4_discovery.o
./obj/stm32f4xx_exti.o ./obj/init.o ./obj/stm32f4xx_rcc.o ./obj/misc.o
./obj/stm32f4xx_syscfg.o ./obj/apptask.o -o elf/base_sp.elf
/opt/rtems-4.11/lib/gcc/arm-rtemseabi4.11/4.7.1/../../../../arm-rtemseab
i4.11/bin/ld:  cannot open linker script file linkcmds.armv7: No such
file or directory
collect2: error: ld returned 1 exit status
make: *** [elf/base_sp.elf] Error 1
Can you tell how to fix this?
von Jörg W. (dl8dtl) (Moderator)
Try running the compiler with -v, then it ought to tell you in which
directories it is looking for the various files.
My guess is that it's the -specs bsp_specs option which might cause
it to look in a non-standard location.
Found the mistake ... the linker file used by ld included another linker
file but with the wrong name
