Forum: FPGA, VHDL & Verilog VHDL code for booth multiplier
Author: mike (Guest)
Ciao,
Dovrei realizzare la descrizione VHDL di un moltiplicatore digitale che
realizzi
l’algoritmo di Booth(con codifica a 2 bit) per due moltiplicandi
rappresentati su N ed M bit rispettivamente e con risultato su N+M bit.
Posto il codice sorgente del moltiplicatore(A) e del test bench(B) che
ho provato a scrivere.
Qualcuno potrebbe dirmi se è corretto?
A) library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity booths is
GENERIC(k : POSITIVE := 7); --input number word length less one
Port ( a,b : in STD_LOGIC_VECTOR (k downto 0);
mul : out STD_LOGIC_VECTOR (2*k+1 downto 0));
end booths;
architecture Behavioral of booths is
begin
process(a,b)
variable m: std_logic_vector (2*k+1 downto 0);
variable s: std_logic;
begin
m:="00000000"&b;
s:='0';
for i in 0 to k loop
if(m(0)='0' and s='1') then
m(k downto k-3):= m(k downto k-3)+a;
s:=m(0);
m(k-1 downto 0):=m(k downto 1);
elsif(m(0)='1' and s='0') then
m(k downto k-3):= m(k downto k-3)-a;
s:=m(0);
else
s:=m(0);
end if;
end loop;
mul<=m;
end process;
end Behavioral;
B)library IEEE;
entity Testbench_di_Booth is
end Testbench_di_Booth;
architecture behavior of Testbench_di_Booth is
component booths
Port( a,b : in STD_LOGIC_VECTOR (k downto 0);
end component;
--Inputs
signal A : STD_LOGIC_VECTOR (7 downto 0):= "00000011";
signal B : STD_LOGIC_VECTOR (7 downto 0):= "00000100";
--Outputs
signal MUL : STD_LOGIC_VECTOR(15 downto 0);
begin
--Instantiate the UnitUnder Test (UUT)
uut: booths PORT MAP
(a => A,
b => B,
mul => MUL);
--Stimulus process
stim_proc: process
begin
--insert stimulus here
A<="00000011"; B<="00000100"; wait for 500 fs;
A<="00000110"; B<="00000111"; wait for 500 fs;
A<="00001011"; B<="00000100"; wait for 500 fs;
wait;
end process;
end;
Author: kfalser (Guest)
No, così no!
There is a lot of people here which is willing to help you if they can,
but nobody wants to spend time for formatting and translation.
Please :
- Ask your question in english
- Format your code in a decent way.
  a) add your source as separate file
  b) use
 and
 tags around your code
  And please, pay attention your code is readable by having a correct
  indentation.
Now it happend to me.
- use the following [vhdl] tags for formatting
Hello,
I should realize the VHDL description of a digital multiplier that
realize Booth's algorithm (encoded in 2 bits) for two terms
represented on N and M bits, respectively, and with a result of N + M
bits.
I have attached the 2 files:
1)booth that should implement the booth's algorithm
2)test that should simulate
Are they correct to implement and simulate a booth's multiplier?
please help me.
You have a testbench.
Why don't you try it out?
I wrote and simulated with ALDEC ACTIVE-HDL Student Edition.
Compile the code and i have 0 Errors, but in the simulation the result
of multiplication is "UUUU" and the WAVEFORM panel is empty.  so I
thought that the codes are wrong.
You have to lern to use the simulator and maybe a little bit more about
VHDL.
The signals are not automatically added to the waveform windows.
You have to select the desired signals and add them to the window.
This is usually done by dragging the signals with the mouse from the
signals window to the waveform window.
Read the tutorial for your simulator.
"U" means that the signal was never initialized or assigned.
This indeed points out that something went wrong. Look at the
intermediate signals to see where you failed.
  • [vhdl]VHDL code[/vhdl]
