Forum: FPGA, VHDL & Verilog If-statement with illegal statements
Author: VHDL_Turtle (Guest)
Hi!
I've got a small problem with my current code and would appreciate any
help.
I tried to find someone with a similar problem, but my google skills
aren't good enough.
This is basically the problem that I'm facing:
generic_a is a generic natural signal, that have to be positive.
slv_a is defined as a STD_LOGIC_VECTOR(15 DOWNTO 0).
   IF (generic_a <= 15) then
      slv_a(generic_a) <= '1';
   END IF;
The problem with this code is when generic_a is bigger then 15. Then I
get an error because the statement above points at a position that is
out of range, even though the illegal statement never will be executed.
How can I solve this without changing the size of slv_a and without
limeting the values that generic_a can take?
Thankful for any help,
VHDL_Turtle
> Then I get an error
Where do you get this error? In simulation? Or in real life?
What kind of error do you get?
Haha! "In real life" :-P
I get the error when I try to simulate the code in ModelSim and I set
generic_a to a big number, say 25.
The error that I get is something like "index out of bounds" (don't have
acces to my code right now so I can't give an exakt error code)
The reason why the code is generating a error is because the middle line
becomes:
 slv_a(25) <= '1'; -- Generates a error even though it is never executed
Which gives an error because slv_a is only defined as 16 bits wide.
How do I remove this problem? Because I still want to be able to
simulate my code when generic_a is big.
Sincerely,
VHDL_Turtle
Try it with a trick and do a modulo operation on generic_a:
   slv_a(generic_a mod 15)
Or because generic_a is a generic and therefore locally constant:
try it with a conditional generate instead of a simple if...
But for better diagnosis there should be more code/information (type
definitions, used packages, ...).
Author: VHDL-Turtle (Guest)
Oh, that little mod-trick is brilliant! That will solve my problem!
Some sort of generate would probably be the best solution to my problem.
But that mod-trick is alot easier then it is to use the concurrent
generate-statement inside a sequencial process statement.
Thank you for your help Lothar!
Sincerely,
VHDL_Turtle
  • [vhdl]VHDL code[/vhdl]
