Forum: ARM programming with GCC/GNU tools Advantages of Hard/Soft FPU Compiler Settings
Author: Patrick (Guest)
Hello,
I'm working with Cortex-M4 MCU using its floating point unit.
It's possible to enable FPU support with following GCC commands:
-mfloat-abi=softfp or  -mfloat-abi=hard
I heard with SoftFloat the code is still compatible for MCUs without
FPU.
Now my question is: Is there any disadvantage e.g. slower performance
using SoftFloat instead of HardFloat ?
What is the code difference between Softfloat and Hardfloat and how is
the Compiler/Controller handling it?
Kind regards,
Patrick
Author: Martin Thomas (Guest)
The ABI defines how user code-calls (library-)functions. There are three
methods:
(1) user-code calls by using the soft-abi, library's interface is
soft-abi and the library uses FPU emulation
(2) user-code calls by using the soft-abi, library's interface is
soft-abi and the library uses hardware-FPU (for example v*-commands on
Cortex-M4)
(3) user-code calls by using hard-abi, library's interface is hard-abi
Libraries are for example the libraries which come with the toolchain
(like libgcc). If libraries for all options are available and all code
of the user-application can be recompiled the 3rd method may have the
advantage that there is no need to transfer registers-content. I did not
look too close into the generated assembly-code to give information
about the "overhead", maybe somebody else can.
As far as I can see (I just made a few tests with STM32F4 Cortex M4 and
GNU tools) the main advantage of the soft-abi is the possiblity to "mix"
libraries which are only available as object code (archives/"a-files").
As long as the library has been compiled with soft-abi and it uses
FPU-emulation internally it can be linked with every other object-code
that uses the soft-abi and everything should work. For hard-ABI all
object-code in the application has to be compiled with this setting and
the hardware-FPU has be be enabled. If a library uses the soft-ABI but
the hardware-FPU interally the interface is compatible with other code
but if the FPU is not enabled there will be core-exceptions.
You may read the getting-started.pdf for Codebench lite from
Mentor/Codesourcery for some more information and the GNU manuals for
even more.
Hope this helps at least it little bit.
Author: Marcus Harnisch (mharnisch)
At least in theory, you will experience slightly lower performance.
Whether this has a noticeable impact on you application depends on the
actual code.
With softfp, floating point function parameters/return values will be
passed in core registers, while hardfp will make use of VFP registers.
Marcus
