Forum: FPGA, VHDL & Verilog decoder (bcd to 7segments)
von bonildo (Guest)
Hi guys, I'm new in VHDL and would be glad if anyone could help me with
my bcd-7segments decoder. I dont know why its not compiling
von P. K. (pek)
Does it work, if you make the last assignment unconditional? And, of
course no semicolons between the elses.
else HEX0 <= "0000000" when a="1000"
else HEX0 <= "0010000"; --when a="1001"
What error message do you get?
Peter K. wrote:
> And, of course no semicolons between the elses.
I also assume the semicolons to be the problem.
Thats not the actual problem, but not doing this will cause the
synthesizer to generate a latch, because only 10 out of the 6561
possible values of a 4 bit std_logic_vector are used (4 digit with each
9 values {UX01ZWLH-} = 9*9*9*9 = 6561). This vast amount of values is of
interest mainly for simulation, but also in real hardware a 4 bit vector
can have 16 values, and therefore there must be a kind of "memory" for
the "last valid" value, if a is greater than 9.
I would change the code so, that if there is a input value greater than
9 a "-" is displayed:
else HEX0 <= "0000000" when a="1000"  --  8
else HEX0 <= "0010000" when a="1001"  --  9
else HEX0 <= "0111111";               --  -
