Forum: FPGA, VHDL & Verilog Help with instruction fetch unit in VHDL
Author: Shay Golan (Guest)
Hello,
In cpu architecture course, we were tasked with building a single cycle
MIPS cpu.
after writing the entire architecture and performing multiple test
benches we wrote the architecture to an fpga board and... it didn't
work.
Examining things closely, we found out there's something wrong with our
instruction fetch. mainly, the PC can't advance to the next instruction
address. I wrote down a simple entity with 2 components - a 32 bits
register and an adder. the register outputs data (program address) to
the adder. the adder performs a "+4" on the address and sends it back to
the PC.
Simple, isn't it?
But it's not working, for some reason - when i simulate this unit it
only has junk on it's bus (XXXXXXXX on modelsim). I can't find the
problem and i'm desperate. i have attached all the relevant files. can
someone find what the problem is?
thank you,
Shay
> benches
With success?
Was the fetch unit in question also tested?
> we wrote the architecture to an fpga board and... it didn't work.
How many clocks do you have in the whole design?
> the PC.
> Simple, isn't it?
The task is fairly simple, your solution is very complicated.
Why using a bunch of files for this simple task?
Why implementing an adder and discarding one bit?
X means there is more then only one driver on this signal..
And you cannot initialize this here with 0
   signal NextPC :std_logic_vector(N-1 downto 0):=zeroes;
and here:
    dataOut:out std_logic_vector(N-1 downto 0):=zeroes
when it is also at the same time an output with an undefined value here:
    signal Q_tmp: std_logic_vector(N-1 downto 0);
    dataOut <= Q_tmp;
This must be the only place to be initialized:
    signal Q_tmp: std_logic_vector(N-1 downto 0) := (others=>'0');
It took me about 2 minutes to locate this fairly common error because i
had to dig around in 3 files. Would the complete code (a simple
registered adder) had been located in 1 file, the you would have seen
the problem yourself...
This is not the testbench you used, is it?
Because you will not be able to compile it:
    process      -- Start of test bench run:
    begin
    clear <= '0';
    wait for 300 ns;
               --------- a endless process?
end TB;
Hi lothar,
thanks for the extensive answer, as for your questions:
the fetch unit was not test benched, because it wasn't designed as a
separate entity. i came back to simulate it once i discovered the
problem lay in that area.
We use a single clock in the design.
the adder we use is the same adder from inside the alu we implemented
for the cpu core, i just used it and inserted a signal which equals
four. I'm using a bunch of files because our implementation for the core
is structural. inside the core entity (which i didn't include in the
files i attached for the reason of keeping my question simple) there's a
data flow from the register to the adder and then to another adder (in
case there's a branch), i chose to implement it that way because it
seemed to me the most modular way to do it.
i will try your solution and see if it works. i'll come back with an
answer.
anyway, thanks a lot for the help - much appericiated! :)
Shay
Author: Shay (Guest)
Thanks! It's working now!
Author: otto (Guest)
>MIPS cpu.
How much time do you get for this task?
  • [vhdl]VHDL code[/vhdl]
