Forum: FPGA, VHDL & Verilog Carrier Generator
von Pratyush A. (pratyush23)
i wish to design a digital carrier generator, the diagram of which i am
attaching herein..
for the same i have used the following building blocks:
1> 2:1 Mux(multibit)
2> Digital Integrator (multibit)
3> A Delta function block (unit impulse function)
4> A Clock
5> A 4x4 bit multiplier, wherein only the first 4 bits of the product
have been considered.
I ran the code and it synthesized perfectly well..but on generation of
test bench waveform, the output ports were undefined..
i m unable to figure out as to how to supply the values to the building
blocks through the signals...
Please suggest the required changes/errors..
Thanks.
von P. K. (pek)
Difficult to say, a number of reasons may be the source:
- Testbench: Are all your inputs defined?
- Non-existing instances (e.g. is your multiplier instantiated?)
- Missing definition of initial values (ever propagating)
Just display the intermediate signals in your waveview and track the
undefined signal(s) down to the root cause. Maybe (if existing) read the
simulator compilation warnings and try to avoid them.
Are you sure?
This code IS ABSOLUTELY NOT synthesizeable!
  for i in 1 to 10 loop
    clock_xhdl0 <= '1';
    wait for 100 ns;
    clock_xhdl0 <= NOT(clock_xhdl0);
    wait for 100 ns;
  end loop;
> but on generation of test bench waveform, the output ports
> were undefined..
I cannot see a testbench in your code. A testbench entity has NO ports.
But each of your modules has ports...
BTW:
A multiplier is in VHDL usually done like this
   a <= b*c;
BTW:
Why using a
   GENERIC (  WIDTH  : INTEGER := 4 );
in your multiplexer, when you later use a fixed vector to extend /a/:
   c <= ("000" & a) WHEN (sel = '1') ELSE    b;
What, if i would take your generic code and write
   GENERIC (  WIDTH  : INTEGER := 6 );
I am unable to update the 4-bit signals(a,b and c) which are used
interchangeably as input and output in the connecting blocks.
Eg. The signal c which is the output of mux is also the input of the 1st
integrator. Since the values are not being updated, as a result the
signals are showing as undefined in the tbw simulation.
von P. K. (pek)
> integrator.
You do not need to update c by hand, this is the task of your
"mux_2to1".
You have to find out why. Observe the signal(s) that influence your
undefined one, e.g. c, in the waveview. In that case, observe a,b and
sel.
Do so recursively with those of the 3 signals (a,b and sel), which are
undefined, until you have found the origin of undefinedness. This will
lead to the earlier posted possible reasons of problems:
- Testbench (not posted...): Are all your inputs defined?
