Forum: FPGA, VHDL & Verilog Short VHDL for loop code i dont understand
von Kasper (Guest)
Hey,
I do understand how to convert a binary number into a decimal number but
the following code thats supposed to do that doesnt make sense. I mean
lets sat we have a binary number 10, then v(i) would be 0, so result
stays 0. Upon the next iteration v(i) will be 1 so result will be 0 + 1
. The loop stops and the function will return the value of result which
is 1 and not 2 which is the value of the binary number put into the
function. Could someone tell me why I am wrong? This code comes with a
university assignment so it should be correct. Thanks. :)
-- convert std_logic vector v to natural
FUNCTION s2n(v: std_logic_vector)
RETURN natural IS
VARIABLE result: natural := 0;
BEGIN
    FOR i IN v'range LOOP
            result := result * 2;
            IF v(i) = '1' THEN
                    result := result + 1;
            END IF;
    END LOOP;
    RETURN result;
END s2n;
Lets define a
signal x : std_logic_vector(1 downto 0);
Then
x'range will result in (1 downto 0)
And so the code
will result in
    FOR i IN 1 downto 0 LOOP
And now, try it once more. First index now is number 1, the second cycle
is index 0...
The major problem of this "university assigned" code is, that it
implicitly assumes, that the vector is ranged with a downto.
It will not work as expected with this vector:
signal x : std_logic_vector(0 to 1);
