Forum: FPGA, VHDL & Verilog HELP VHDL code for ADC at FPGA
Author: vicky d. (vicky_d)
1 useful
I want use ADC at FPGA, but honestly i didnt understand to coding at
FPGA use VHDL..
my project is to read output from saensor CO, but before go to there.. i
want to try coding simple AD with input 5volt and i can see the output
from FPGA..
can someone help me? or give me good tutorial.. cause i already search
but only get code without good explanation with that code..
thanx so much,
Author: Nop (Guest)
Where are the information?
What (kind of) FPGA?
What (kind of) Sensor?
my FPGA Spartan 3E.. sensor MQ 7 for Carbon monoksida, but i just want
to try read input data 5volt from FPGA..
> but i just want to try read input data 5volt from FPGA.
Lets try this way:
  1.          2.        3.             4.                   5.
sensor   -> 0..5V   -> adc   ->  serial/SPI/parallel   -> fpga
1. http://www.sparkfun.com/products/9403
2. voltage interface
3. unknown
4. unknown
5. S3E
You don't want to code an adc. I suppose you simply want to code the
interface to the adc...
>  and i can see the output from FPGA..
Where do ypou want to see the output?
A fpga itself has no display or whatsoever...
ok i just want make clear my question.
i just want to know how to read ADC from FPGA and i just make example
input is 1-5 volt. and the output is biner or hexa? and i want see the
output at LED..
so if any1 can help me to explain it im very appreciate it.
Author: SomeUser (Guest)
Hey vicky,
I got a premontion that you want to build a AD-Converter within an fpga.
If I'm right, that this is not possible. If you just want to access an
existing AD-Converter by using your fpga, than you'll have to follow the
links posted an see, how this is could be archieved.
Have a nice day,
some user.
Which ADC? There are thousands of ADCs and a big bunch of possible
interfaces. Draw a picture/schematic of your system and/or answer the
question i asked already.
>> 3. unknown
>> 4. unknown
binary, octal, hexadecimal or decimal are just different views on the
same value. Lets say, you have a value of 100dez this is then binary
001100100 and also 64hex and also 144oct. But its always the very same
value!
Have you previously done such a thing with e.g. a microcontroller?
Whats your knowledge level? Beginner?
There are FPGAs on the market equipped with an on-chip ad converter.
Actel/Microsemi has them...
No double postings please.
Author: Just1Bit (Guest)
Simple 1-Bit ADC in VHDL:
LED <= SENSOR;
Have fun
Author: varun maheshwari (Company: DEI) (varun_agr)
you have to configure your ADC chip if u r interfacing ADC to FPGA kit
by using datasheet of that ADC . You have to write .ucf file for the
same and for displaying result you have to use LCD or serial
communication. But again for this u have to write code for LCD and
serial programming. If you want to use LED for o/p then u have to use
switches combination and also see manual for writing ucf
file(switches,LED,ADC,clock).
Author: Sangita Gujarkar (Guest)
I want to interface ADC to CPLD, but honestly i didnt understand to
coding at
cpld use VHDL..
 i want to try coding simple AD7705 with input 5volt and i can see the
output
from CPLD XC9572.on swiches(LEDS)
thanx so much,
  • [vhdl]VHDL code[/vhdl]
