Forum: FPGA, VHDL & Verilog interface fpga through microcontroller
von pw (Guest)
Hi Guys,
I need to do image processing. I first considered doing it through
android NDK, but can only accomplish that much.
I'm currently designing a hand-held device that would attempt to do
indoor navigation through image processing (edge detection of rotated
images).
So ideally I would like to connect the smartphone to a microcontroller
and connecting that to the fpga. In one cycle, the smartphone should
send 2 individual image buffers to the microcontroller, from there being
processed and compared with the fpga.
My question is, after accomplishing this with a development board, which
low-cost fpga could I buy, and what is needed for a working serial
interface between the microcontroller and fpga?
Any links and advice will be appreciated. quite a noob with FPGAs.
von P. K. (pek)
Did you already complete this task on a development board? After doing
so, you should be able (if not yet, you will be able afterwards) to
answer some of the following questions:
- Is the resulting system fast enough for your needs? (You interface
from the phone to a microcontroller, maybe through USB 2 or 3, and from
there you want to have a serial interface to your FPGA, maybe LVDS or
multiple LVDS. So the data path will be quite busy if you want
reasonable fast navigation).
- What complexitiy are the algorithms you are using on the FPGA?
- How many pictures you want to process in what time?
- Is the memory on the FPGA sufficient for your needs or do you require
intermediate storage close to the FPGA? What kind of stroage?
- What feedback information do you want to provide to which instance
(controller, smart phone, any other)?
- What power dissipation requirements do you have (handheld...)?
From answering these questions (and for sure a couple more will occur),
the integration from the development board functional model to your
desired system will lose some degrees of freedom...
...however to my opinion, there will be a lot more limiting factors than
just "low cost", at least for a prototype.
