hi... i want to know whether for loop in vhdl is synthesizable or not???
Yes, it is synthesizable. But it will create parallel logic. Best regards, Marius
Marius Wensing wrote: > Yes, it is synthesizable. But it will create parallel logic. > > Best regards, > Marius so what it means parallel logic? dose it creats any problem in design later?
> i want to know whether for loop in vhdl is synthesizable or not??? Yes it is, but it will produce completely different results than a loop in any software programming language! > so what it means parallel logic? In software a loop will be processed one loop after the other, in hardware ALL of the loops will exist next to each other. And the whole loop will be executed the very same time! > dose it creats any problem in design later? Try it with a short and simple sample code... Or: show your code...
