Forum: FPGA, VHDL & Verilog Modelsim Vhdl library lpm not found.
von nehssen s. (nehsr)
Hello,
When compiling my program, the following error is being printed:
Library lpm not found.
Is there anything i can do to resolve that in modelsim?.....
Which one?
Pls read your own post WITHOUT ANY knowledge about your problem. You
will see: there is not nearly enough information for any hint!
And: do you know Google?
http://www.google.com/search?q=Library+lpm+not+found
von Duke Scarring (Guest)
5 bucks for the solution:
run
vlib lpm
in your simulation directory...
Duke
says : ''cannot find expanded name "lpm.lpm_components".
I've looking on google and apparently i need a folder termed as
"220model"?
Here is the code i want to simulate :
LIBRARY lpm;
USE lpm.lpm_components.ALL;
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
PACKAGE mul_package is -- user defined components
  COMPONENT ccmul
    GENERIC (W2 : INTEGER := 17; --multiplier bit width
              W1 : INTEGER := 9; --bit width C+S SUM
              W   : INTEGER := 8); -- Input bit width
              PORT
              (clk : IN STD_LOGIC; -- clock for the output register
              x_in, y_in, c_in : IN STD_LOGIC_VECTOR(W-1 DOWNTO 0);
              --INPUTS
              cps_in, cms_in : IN STD_LOGIC_VECTOR(W-1 DOWNTO 0);
              --INPUTS
              r_out, i_out : OUT STD_LOGIC_VECTOR(W-1 DOWNTO 0));
              --RESULTS
            END COMPONENT;
          END mul_package;
LIBRARY work;
USE work.mul_package.ALL;
LIBRARY ieee;
USE ieee.std-logic_1164.ALL;
LIBRARY lpm;
LIBRARY ieee;
USE ieee.std_logic_unsigned.ALL;
ENTITY bfproc IS
  GENERIC ( W2 : INTEGER := 17;  --multiplier bit width
  W1 : INTEGER := 9;
  W : INTEGER := 8);
  PORT
  (clk    :STD_LOGIC;
  Are_in, Aim_in, c_in, --8 bit inputs
  Bre_in, Bim_in : IN STD_LOGIC_VECTOR(W-1 DOWNTO 0);
  cps_in, cms_in : IN STD_LOGIC_VECTOR(W1-1 DOWNTO 0); --9 bits
coefficients
  Dre_out, Dim_out, --8bit results
  Ere_out , Eim_out : OUT STD_LOGIC_VECTOR(W1 DOWNTO 0));
END bfproc;
ARCHITECTURE flex OF bfproc IS
  SIGNAL dif_re, dif_im         --Bf out
  : STD_LOGIC_VECTOR(W-1 DOWNTO 0);
  SIGNAL Are, Aim, Bre, Bim : integer RANGE -128 TO 127;
  --inputs as integers
  SIGNAL c : STD_LOGIC_VECTOR(W-1 DOWNTO 0);
  --input
  SIGNAL cps, cms : STD_LOGIC_VECTOR(W1 DOWNTO 0);
  --RESULTS
BEGIN
  PROCESS --compute the additions of the butterfly using
    BEGIN -- integers and store inputs in flip flops
      WAIT UNTIL clk = '1';
      Are <= CONV_INTEGER (Are_in);
      Aim <= CONV_INTEGER(Aim_in);
      Bre <= CONV_INTEGER(Bre_in);
      Bim <= CONV_INTEGER(Bim_in);
      c <= c_in; --load from memory cos
      cps <= cps_in; --load from memory cos+sin
      cms <= cms_in; --Load from memory cos-sin
      Dre_out <= CONV_STD_LOGIC VECTOR (Are + Bre )/2, W);
      Dim_out <= CONV_STD_LOGIC_VECTOR(Aim + Bim)/2, W);
    END PROCESS;
    --No FF because butterfly difference ''diff'' is not an output port
    PROCESS (Are, Bre, Aim, Bim)
      BEGIN
        dif_re <= CONV_STD_LOGIC_VECTOR(Are/2 - Bre/2, 8);
        dif_im <= CONV_STD_LOGIC_VECTOR(Aim/2 - Bim/2,8);
      END PROCESS;
von enan (Guest)
this is the line which causes your error. You should check if you are
really using components out of that library.
von Marius W. (mw1987)
Here is a typo, too!
von user (Guest)
you have to compile the xilinx libaries with
compxlib -s mti_pe -f all -l all -o ./
see also:
http://www.xilinx.com/support/answers/15338.htm
Xilinx? LPM are "Megafunctions" from Altera...     :-o
http://www.altera.com/support/software/eda_maxplus2/synopsys/fpgaex/fpxlpm.html
von ahmed (Guest)
thanks u
Just for completeness, here is a kind of compxlib for Altera. Stratix
IV (Makefile):
.ONESHELL:
.SILENT:
QUARTUS_PATH = ..
COMPILED_PATH = compiled_libs
FLAGS =  -93  -quiet
VFLAGS = -vlog01compat  -quiet
all: clean build_verilog build_vhdl
build_verilog:
  cd compiled_libs
  vlib altera_ver
  vlib sgate_ver
  vlib lpm_ver
  vlib altera_mf_ver
  vlib stratixiv_ver
  vmap altera_ver       ${COMPILED_PATH}/altera_ver
  vmap sgate_ver        ${COMPILED_PATH}/sgate_ver
  vmap lpm_ver          ${COMPILED_PATH}/lpm_ver
  vmap altera_mf_ver    ${COMPILED_PATH}/altera_mf_ver
  vmap stratixiv_ver    ${COMPILED_PATH}/stratixiv_ver
  vlog  ${VFLAGS} -work altera_ver    ${QUARTUS_PATH}/sim_lib/altera_primitives.v
  vlog  ${VFLAGS} -work sgate_ver     ${QUARTUS_PATH}/sim_lib/sgate.v
  vlog  ${VFLAGS} -work lpm_ver       ${QUARTUS_PATH}/sim_lib/220model.v
  vlog  ${VFLAGS} -work altera_mf_ver ${QUARTUS_PATH}/sim_lib/altera_mf.v
  vlog  ${VFLAGS} -work stratixiv_ver ${QUARTUS_PATH}/sim_lib/stratixiv_atoms.v
30
31
32
build_vhdl:
33
  cd compiled_libs
34
  vlib altera
35
  vlib lpm
36
  vlib stratixiv
37
38
  vmap altera       ${COMPILED_PATH}/altera
39
  vmap lpm          ${COMPILED_PATH}/lpm
40
  vmap stratixiv    ${COMPILED_PATH}/stratixiv
41
42
  vcom ${FLAGS} -work  altera ${QUARTUS_PATH}/sim_lib/altera_primitives_components.vhd
43
  vcom ${FLAGS} -work  altera ${QUARTUS_PATH}/sim_lib/altera_primitives.vhd
44
45
  #vcom ${FLAGS} -work  lpm ${QUARTUS_PATH}/fv_lib/vhdl/lpms/lpm_components.vhd
46
  #vcom ${FLAGS} -work  lpm ${QUARTUS_PATH}/fv_lib/vhdl/lpms/lpm_and.vhd
47
  #vcom ${FLAGS} -work  lpm ${QUARTUS_PATH}/fv_lib/vhdl/lpms/lpm_mux.vhd
48
  #vcom ${FLAGS} -work  lpm ${QUARTUS_PATH}/fv_lib/vhdl/lpms/lpm_or.vhd
49
  #vcom ${FLAGS} -work  lpm ${QUARTUS_PATH}/fv_lib/vhdl/lpms/lpm_xor.vhd
50
51
  vcom ${FLAGS} -work  stratixiv ${QUARTUS_PATH}/fv_lib/vhdl/stratixiv/stratixiv_components.vhd
52
  vcom ${FLAGS} -work  stratixiv ${QUARTUS_PATH}/sim_lib/stratixiv_atoms.vhd
53
  vcom ${FLAGS} -work  stratixiv ${QUARTUS_PATH}/sim_lib/stratixiv_components.vhd
54
55
56
clean:
57
  /bin/rm -rf  altera
58
  /bin/rm -rf  lpm
59
  /bin/rm -rf  stratixiv
60
61
  /bin/rm -rf altera_ver
62
  /bin/rm -rf lpm_ver
63
  /bin/rm -rf sgate_ver
64
  /bin/rm -rf altera_mf_ver
65
  /bin/rm -rf stratixiv_ver
