Hello,
So this is my code for the butterfly architecture of my
program.......... when compiled it says : component(40): "add":
expecting ';'
component(41): "sub": expecting ';' and it continues so on for all the
other components..........
my code is as follows:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.MATH_REAL.ALL;
library work;
use work.fft_pkg.all;
entity butterfly is
port(
s1,s2 : in comp_array; --inputs
w :in comp_array; -- phase factor
x1_out,x2_out :out comp_array -- outputs
end butterfly;
architecture Behavioral of butterfly is
signal xxx : integer := 0;
type comp_array is array (0 to 7) of complex;
type comp_array2 is array (0 to 3) of complex;
function add (x1,x2,x3 : comp_array) return comp_array;
function sub (x1,x2,x3 : comp_array) return comp_array;
function mult (x1,x2,x3 : comp_array) return comp_array;
begin
--butterfly equations.
process
function add (x1,x2,x3 : comp_array) return comp_array is
function sub (x1,x2,x3 : comp_array) return comp_array is
function mult (x1,x2,x3 : comp_array) return comp_array is
begin
--1st stage equations:
x1(0) := s(0) add (s(4) mult w);
x1(1) := s(0) sub (s(4) mult w);
x1(2) := s(2) add (s(6) mult w);
x1(3) := s(2) sub (s(6) mult w);
x1(4) := s(1) add (s(5) mult w);
x1(5) := s(1) sub (s(5) mult w);
x1(6) := s(3) add (s(7) mult w);
--2nd stage equations:
x2(0) := x1(0) add (x1(2) mult w(0));
x2(2) := x1(0) sub (x1(2) mult w(0));
x2(3) := x1(1) add (x1(3) mult w(2));
x2(1) := x1(1) sub (x1(3) mult w(2));
x2(6) := x1(4) add (x1(6) mult w(0));
x2(4) := x1(4) sub (x1(6) mult w(0));
x2(7) := x1(5) add (x1(7) mult w(2));
x2(5) := x1(5) sub (x1(7) mult w(2));
--3rd stage equations:
x3(0) := x2(0) add (x2(4) mult w(0));
x3(4) := x2(0) sub (x2(4) mult w(0));
x3(1) := x2(1) add (x2(5) mult w(1));
X3(5) := x2(1) sub (x2(5) mult w(1));
x3(2) := x2(2) add (x2(6) mult w(2));
x3(6) := x2(2) sub (x2(6) mult w(2));
x3(3) := x2(3) add (x2(7) mult w(3));
x3(7) := x2(3) sub (x2(7) mult w(3));
end process;
end Behavioral;
Much appreciated if you could help me please anyone..........
so fft_pkg is as follows :
library IEEE; -- library name and library use clause
use IEEE.std_logic_1164.all; -- specifies multi level logic system
package fft_pkg is
type complex is
record
r : real;
i : real;
end record;
function add (n1,n2 : complex) return complex;
function sub (n1,n2 : complex) return complex;
function mult (n1,n2 : complex) return complex;
end fft_pkg;
package body fft_pkg is
--addition of complex numbers
function add (n1,n2 : complex) return complex is
variable sum : complex;
begin
sum.r:=n1.r + n2.r;
sum.i:=n1.i + n2.i;
return sum;
end add;
--subtraction of complex numbers.
function sub (n1,n2 : complex) return complex is
variable diff : complex;
begin
diff.r:=n1.r - n2.r;
diff.i:=n1.i - n2.i;
return diff;
end sub;
--multiplication of complex numbers.
function mult (n1,n2 : complex) return complex is
variable prod : complex;
begin
prod.r:=(n1.r * n2.r) - (n1.i * n2.i);
prod.i:=(n1.r * n2.i) + (n1.i * n2.r);
return prod;
end mult;
end fft_pkg;
hello duke,
any chance you can propose me with a model for the line
i'd be really grateful my friend............. Please, it's a project and
i really need this........
Dear Duke,
following your advice, i remodelled the program into this:
but the problem still exists
library IEEE;
library work;
entity butterfly is
port(
end butterfly;
begin
process
begin
variable diff : comp_array;
x1(1) := s(0) sub; (s(4) mult w);
x1(3) := s(2) sub; (s(6) mult w);
x1(5) := s(1) sub; (s(5) mult w);
return diff;
end sub;
variable sum : comp_array;
--2nd stage equations (sum):
--3rd stage equations(sum):
return sum;
end add;
end process;
end Behavioral;
Any chance you point me with a model please?........
Where is s defined?
library IEEE;
library work;
entity butterfly is
port(
end butterfly;
i reckon it should be
port(
s, s1,s2 : in comp_array; --inputs
instead?
library IEEE;
library work;
use work.fft_pkg.ALL;
type complex is
record
r : real;
i : real;
end record;
entity fft8 is
port( s : in comp_array; --input signals in time domain
y : out comp_array --output signals in frequency domain
end fft8;
architecture Behavioral of fft8 is
component butterfly is
port(
s1,s2 : in complex; --inputs
w :in complex; -- phase factor
g1,g2 :out complex -- outputs
end component;
signal g1,g2 : comp_array := (others => (0.0,0.0));
--phase factor, W_N = e^(-j*2*pi/N) and N=8 here.
--W_N^i = cos(2*pi*i/N) - j*sin(2*pi*i/N); and i has range from 0 to 7.
constant w : comp_array2 := ( (1.0,0.0), (0.7071,-0.7071), (0.0,-1.0),
(-0.7071,-0.7071) );
port(
x1,x2 :out complex -- outputs
end component;
begin
--first stage of butterfly's.
bf11 : butterfly port map(s(0),s(4),w(0),x1(0),x1(1));
bf12 : butterfly port map(s(2),s(6),w(0),x1(2),x1(3));
bf13 : butterfly port map(s(1),s(5),w(0),x1(4),x1(5));
bf14 : butterfly port map(s(3),s(7),w(0),x1(6),x1(7));
--second stage of butterfly's.
bf21 : butterfly port map(x1(0),x1(2),w(0),x2(0),x2(2));
bf22 : butterfly port map(x1(1),x1(3),w(2),x2(1),x2(3));
bf23 : butterfly port map(x1(4),x1(6),w(0),x2(4),x2(6));
bf24 : butterfly port map(x1(5),x1(7),w(2),x2(5),x2(7));
--third stage of butterfly's.
bf31 : butterfly port map(x2(0),x2(4),w(0),x3(0),x3(4));
bf32 : butterfly port map(x2(1),x2(5),w(1),x3(1),x3(5));
bf33 : butterfly port map(x2(2),x2(6),w(2),x3(2),x3(6));
bf34 : butterfly port map(x2(3),x2(7),w(3),x3(3),x3(7));
entity butterfly is
port(
end butterfly;
(signals are complex)
port(
end component;
(number of signals didn't fit with the first entity of butterfly)
Alright, removing the s frim the input array in the entity, still, the
problem is persisting....
> but to answer your question straight forward, the input signals are s1> and s2 only....
Ok. But in your equation you ask for s. And it is defined elsewhere...
[vhdl
entity butterfly is
port(
s1, s2 : in comp_array; --inputs
w : in comp_array; -- phase factor
x1_out, x2_out : out comp_array -- outputs
end butterfly;
function add (x1, x2, x3 : comp_array) return comp_array;
function sub (x1, x2, x3 : comp_array) return comp_array;
function mult (x1, x2, x3 : comp_array) return comp_array;
begin
process
[/vhdl]
Ok so far.
honestly mate,
am a newbie in vhdl, anything you can help with here ma man, anything
which could sort it out?.......... Please, it looks like you know what
to do....
library IEEE;
library work;
entity butterfly is
port(
x1_out,x2_out :out complex -- outputs
end butterfly;
begin
return diff;
end sub;
return sum;
end add;
end process;
end Behavioral;
