Forum: µC & Digital Electronics Starting From Flash
Author: Rodi07 (Guest)
hello,
i´m working with SAM7-EX256 Board "at91sam7x256", and ARM-USB-TINY-H.
I will start my program from the flash. If i load the program to the
flash i get this message:
Open On-Chip Debugger 0.4.0 (2010-11-23-14:20)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.berlios.de/doc/doxygen/bugs.html
srst_only srst_pulls_trst srst_gates_jtag srst_open_drain
1000 kHz
Info : max TCK change to: 30000 kHz
Info : clock speed 1000 kHz
Info : JTAG tap: sam7x256.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787,
part: 0xf0f0, ver: 0x3)
Info : Embedded ICE version 1
Info : sam7x256.cpu: hardware has 2 breakpoint/watchpoint units
Warn : srst pulls trst - can not reset into halted mode. Issuing halt
after reset.
target state: halted
target halted in ARM state due to debug-request, current mode:
Supervisor
cpsr: 0x20000093 pc: 0x000000a0
Warn : NOTE! DCC downloads have not been enabled, defaulting to slow
memory writes. Type 'help dcc'.
Warn : NOTE! Severe performance degradation without fast memory access
enabled. Type 'help fast'.
dcc downloads are enabled
background polling: on
TAP: sam7x256.cpu (enabled)
Supervisor
flash 'at91sam7' found at 0x00100000
auto erase enabled
auto unlock enabled
wrote 16384 bytes from file at91sam7x_getting_started_flash.bin in
3.625000s (4.414 kb/s)
shutdown command invoked
but i can not start it.
any idea?
Rodi07
: Moved by Admin
Author: guest (Guest)
Have you tried the reset command in openocd or the reset button of your
target board?
guest
yes in my board
Can you post your elf-file? Maybe something is linked wrong.
I can do that no problem, but I load my bin file into the Flash.
The entry point is ok. The code starts from 0x00100000.
How do you flash die bin-file?
Author: Günther (Guest)
> 0x3f0f0f0f
check your TDO signal. Then TCK.
@ Günther:
my TCK from SPI1 is of high: 2.9V und my MOSI of 0V, MISO 2.9V
@guest: with this function in my cfg-file.
proc program_device () {
  #halt the processor
  halt
  wait_halt
  #write file to flash memory
  arm7_9 dcc_downloads enable
  sleep 10
  poll
  flash probe 0
  flash write_image erase unlock "at91sam7x_getting_started_flash.bin"
0x00100000
  sleep 10
  #start execution of the program just downloaded
  reset run
  sleep 10
  #exit OpenOCD
  shutdown
$_TARGETNAME configure -work-area-phys 0x00200000 -work-area-size 0x4000
-work-area-backup 0
#flash bank <driver> <base_addr> <size> <chip_width> <bus_width>
<target_number> [<target_name> <banks> <sectors_per_bank>
<pages_per_sector> <page_size> <num_nvmbits> <ext_freq_khz>]
set _FLASHNAME $_CHIPNAME.flash
flash bank $_FLASHNAME at91sam7 0 0 0 0 $_TARGETNAME 0 0 0 0 0 0 0 18432
init
reset init
at91sam7 gpnvm 0 2 set
program_device ()
# For more information about the configuration files, take a look at:
# openocd.texi
Thanks
rodi
hard to tell whats happening, but this line describes the problem:
So on JTAG the programmer determines an IDCODE of 3F0F0F0F, which is
00111111000011110000111100001111 (mfg, part and ver are partial bit
sequences).
This is what the device returns on TDO when clocked via TCK. The right
IDCODE is part of the datasheet. I assume it does not look like 3F0F...
