Forum: ARM programming with GCC/GNU tools Problem of debugging without flash
Author: XuFangbo (Guest)
Hi
Thanks in advance for reading my post.
I am doing a project with a platform without any flash memory. This
platform has the AM3517 processor. Before using this platform, I
simulate it in craneboard. What I did is that I locate all sections to
ram, Here is my linker scriptfile.
** Sample linker definition file for NP30.
EXTERN(_start)
ENTRY(_start)
MEMORY
   vectors   : org = 0x4020ffc4,   len = 0x003C
   intram    : org = 0x40200040,   len = 0x3800
   sdram     : org = 0x80000000,   len = 0x100000
SECTIONS
   .boot             : { __BOOT_START = .; *(.boot) __BOOT_END = .; . =
ALIGN( 4 ); }> vectors
   .startup          : { __BOOT_START = .; *(.boot) __BOOT_END = .; . =
ALIGN( 4 ); } > intram
   .text             : { __TEXT_START = .; *(.text) __TEXT_END = .; . =
ALIGN( 4 ); } > sdram
   .rdata            : { __RDATA_START = .; *(.rodata) *(.rodata.str1.2)
*(.rodata.str1.4) *(.rdata_4) *(.rdata_2) *(.rdata_1) __RDATA_END = .; .
= ALIGN( 4 ); } > sdram
   .data             : { __DATA_START = .; *(.data_4) *(.data_2)
*(.data_1) *(.data) __DATA_END = .; . = ALIGN( 4 ); } > sdram
   .bss    (NOLOAD)  : { __BSS_START = .; *(.bss_4) *(.bss_2) *(.bss_1)
*(.bss) *(COMMON) __BSS_END = .; . = ALIGN( 16384 ); } > sdram
   .mmutable (NOLOAD): { __MMUTABLE_END = .; . += 0x4000;
__MMUTABLE_START = .; . = ALIGN( 16384 ); } > sdram
   .sysstack         : { __SYSSTACK_END = .; . += 0x200;
__SYSSTACK_START = .; . = ALIGN( 4 ); } > intram
   .irqstack         : { __IRQSTACK_END = .; . += 0xE0; __IRQSTACK_START
   .fiqstack         : { __FIQSTACK_END = .; . += 0x80; __FIQSTACK_START
   .abtstack         : { __ABTSTACK_END = .; . += 0x80; __ABTSTACK_START
   .svcstack         : { __SVCSTACK_END = .; . += 0x80; __SVCSTACK_START
   .undstack         : { __UNDSTACK_END = .; . += 0x80; __UNDSTACK_START
However, in the map file, I found that section
.debug_*,.comment,.attributes are still located to the address which
starts with 0x00000000, and this is the address where the flash is
mapped. I add three lines in order to relocate these sections:
   .comment              : { *(.comment) ; . = ALIGN( 4 ); } > sdram
   .attributes     : { *(.ARM.attributes) ; . = ALIGN( 4 ); } > sdram
   .debug                : { *(.debug*) ; . = ALIGN( 4 ); } > sdram
and I Checked the .out file using "file" command, it says "Reading
symbols from XXX.out, <no debugging symbols found>....done".
Can someone help me? Thanks
