Forum: FPGA, VHDL & Verilog verilog/vhdl code for programmable parallel to serial converter
Author: anjali komalapati (Company: iqi labs) (anjali)
can any 1 help me in writing a code for 6 to 16 bit programmable
parallel to serial converter.......
Maybe. What do you have already done? Show your work and then ask your
questions.
> for 6 to 16 bit programmable parallel to serial converter.
Is that a simple loadable shift register?
Draw a picture or just add more information.
You should have a close look on your dot key. Maybe its stuck.
i attatched my code what i have written so plz check it out and say me
where should i modify
A loop is the totally wrong way.
A loop in VHDL implements several instances of the described part inside
the loop in parallel. It does something completely different than a
loop in C. What you need is a counter and a schift register...
This here is a little bit tricky:
process( clk)
variable x : integer := 6;
begin
  if DataReady = '1' then    -- DataReady is missing in the sensitivity list
     if (clk'event and clk = '1') then
This you should write that way (as anyone else in the world does):
process( clk)
begin
  if (clk'event and clk = '1') then   -- FIRST there has to be a clock!
And: you will not need a variable for this simple task.
A variable also does not do that what you expect...
BTW: attach your code as a *.vhdl file (not as *.txt) and you will see a
little magic...
so plzzzz help me still where should i modify the code to get the
appropriate result without using a variable.....
Let me say its a fairly simple task.
I'm really astonished about your problems....  :-o
Try to understand this:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity P2S is
port ( Serial_out     : out std_logic;
       clk            : in std_logic;
       Parallel_data  : in std_logic_vector(15 downto 0);
       DataReady      : in std_logic);
end P2S;
architecture Behavioral of P2S is
signal OldReady : std_logic := '0';
signal Shreg    : std_logic_vector( 15 downto 0);
begin
  process (clk) begin
      Shreg <= '0' & Shreg(15 downto 1);     -- shift it left to right
      if DataReady='1' and OldReady='0' then -- rising edge = new data
        Shreg <= parallel_data;              -- load it
      end if;
    end if;
  End process;
  Serial_out <= Shreg(0);
end Behavioral;
I use a little trick so that its not necessary for me to check the
length: if all of the bits are transmitted, with evere clock a '0' is
shifted out.
ya it is fine but nw here if we get 16 bit data dat is geting serialized
but sometimes i may get 6 bit r 8 bit r 10 bit r etc at dat time dat can
get into serialized. How this can be known according to ur logic........
Nobody can know that. Because there is no information how much of the 16
bits contain "real" data. Lets take the word "0000_1001_0011_0001". Is
it 12 bits or 16 bits long?
Lets transmit 6 bit like this: "110011"? How will it look like?
clk  _-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
data _______________----____----_____________
Where does the frame start?
Whats the difference to a 8 bit word like "00110011"? How does this look
like? Tahke this:
You see: you cannot see a difference!
So usually you will need a frme signal that tells you, when a telegram
starts and when it ends. Then you can easily seen how long the data
telegram is:
frame __________----------------_____________
This was 8 bits.
frame ______________------------_____________
And this was 8 bits.
The whole thing is realized like a SPI interface.
so wt ever the length of the data we get, that will get serialized
according to this logic and but here you took 16 bit if i get the data
of 8 r 10 bit length of data so that many bits get serialized and gives
the output?
Did not get your question...  :-/
> if i get the data of 8 r 10 bit length
What would you input to the P2S unit?
The input port has 16 bit witdh:
entity P2S is
port ( ....
How do you go into this unit with 8 or 10 bits?
ya input is fixed length of 16 bit but this parallel to serial converter
logic should be programmable when ever the data will arrive then dat
should get serialized. For example 1st i got the data of 6 bit length at
that time that data should be latched then it should get serialized.
Similarly some other time when i get the data of length10 bit even in
same way that should get serialized. This means our logic should be 1
time programmed instead of runtime programmable......... I think u got
my point
Iam attatching one more file it is nt simulating i have written this
type also so Once check this also compare my previous reply  and say me
plzzzz........
Thats exactly, what my previously posted code does...
> some other time when i get the data of length10 bit even in same way
And HOW can cou see this difference of 4 bits on a 16 bit vector?
How can you KNOW the witdh of the actual vector?
> I think u got my point
Yes, i do, but not vice versa.
Draw a picture with different parallel input vectors and how the have to
occur on the serial output...
EDIT:
> it is nt simulating
Why? Whats the problem?
>  counter<=counter+1;
Counter is an integer. And an integer can get much higher values than
the index here will be allowed to:
> Serial_out<=Parallel_data(counter);
ya if we get 6 bit data at that time as we have given fixed length is 16
bit in that it takes 6 bit of data and remaining will send as zeros
without affecting the data. This way it will happen  na?
Yes. Try it with a simulation...
Thank you so much for your support. your posts are helped me alot
Author: Susan L. (susan_l)
here is another method to design parallel to serial converter
http://appliedelectronicsengineering.blogspot.com/...
this is much easier to understand
  • [vhdl]VHDL code[/vhdl]
