Forum: FPGA, VHDL & Verilog WARNING:Xst:2677: how to eliminate this warning?
von deepak s. (dksagra)
WARNING:Xst:2677 - Node <rand_temp_0> of sequential type is unconnected
in block <filter_k>.
von Ingo (Guest)
Stupid?
warning is stupid or you are telling about yourself?
von PittyJ (Guest)
Perhaps you should read the text of the warning.
Then think about it, e.g. what means 'unconnected'.
Then look into your design and repair it.
Connect the unconnected lines.
For a answer that goes more into detail you must provide your code.
Why do you post your question 3 times?
> warning is stupid
Yes, also...
von shyamala (Guest)
Xst:2677 - Node <adc_reg_data_8> of sequential type is unconnected in
block <adc_top_interface_2>.
Did you read the 5 year old thread befor posting your question?
The problem is somewhere in your code. Just have a look for the signal
in question...
BTW: I will not open any *.docx file of an unknown source. Simply attach
a text file with the messages or copy them straight to the edit box.
von Markus F. (mfro)
if you intentionally want to leave an output port unconnected, you can
indicate this to the tools with the keyword "open" in the port map.
