Forum: FPGA, VHDL & Verilog Error Loading Design Model Sim PE student edition 10.1
von Amit Ram S. (amitram_s)
I installed ModelSim PE Student Edition 10.1 on Windows 7 32-bit OS in
January 2012. I am able to compile the verilog files without any error.
But when i try to load the design for simulation i get the error message
as shown below. I copied the "student_license.dat" file into the
installation directory of ModelSim as specified in email from Mentor
Graphics.
Please provide a solution to this problem. Thanks in advance.
vsim -coverage work.ones_cntr_tb
# //  ModelSim PE Student Edition 10.1 Dec  6 2011
# //  Copyright 1991-2011 Mentor Graphics Corporation
# //  All Rights Reserved.
# //  THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
# //  WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION OR ITS
# //  LICENSORS AND IS SUBJECT TO LICENSE TERMS.
# // NOT FOR CORPORATE OR PRODUCTION USE.
# // THE ModelSim PE Student Edition IS NOT A SUPPORTED PRODUCT.
# // FOR HIGHER EDUCATION PURPOSES ONLY
# vsim -coverage work.ones_cntr_tb
# ** FATAL ERROR: ModelSim PE Student Edition licensing failure due to
one or more problems with the license key such as:
# - it is not found
# - it has expired
# - it is not for this user
# - it is not for this computer
# - it is not for this version of ModelSim PE Student Edition.
# Please go to http://www.model.com and download an updated copy of the
# Error loading design
von user (Guest)
you have to define a environment variable
LM_LICENSE_FILE="pathtolicencefile/licensefile"
I defined a environment variable "LM_LICENSE_FILE" pointing to the
"student_license.dat" file, but i am still getting the same error
message as described previously.
I have installed Model Sim in E: drive instead of the default C: drive.
Is the error occuring due to installation in a non-default location ?
von Duke Scarring (Guest)
Check your lincens setup with the programs "lmtool" or "Licensing
Wizard".
Duke
von Mathi (Guest)
Modelsim PE does not support coverage without an optional package. Have
you tried to start the simulation without -coverage ?
I tried loading the design by removing the coverage option. But, i am
still getting the same error message.
vsim work.ones_cntr_tb
# - it is not found
# - it has expired
von akash (Guest)
the same problem is occurring with me.
i have set the the new variable and have given the path to license file.
even then i am getting the same here as below
vsim -gui
# Start time: 09:54:18 on Jul 10,2018
# - it is not found
# - it has expired
von Karim M. (kami13)
I am struggling with the same problem....the only solution seems to
uninstall and install the software again and ask for new license..but it
is unpractical...it seems the license is linked to the IP
is there another reliable light(size not big)  VHDL simulator to use?
von Latha p (Guest)
I installed Modelsim PE latest student verrsion two many ,but i am
getting the following erroe
von obsa (Guest)
