Forum: ARM programming with GCC/GNU tools Creating .elf from assembler
Author: Jimmy (Guest)
Hello,
I am trying to create an .elf file from ARM assembly code needed for
ARMulator.
But whenever I try to compile the code with arm-elf-gcc, I get a 'bad
instruction' error for every sing line, but compiling the code under
keil makes no problem.
The code:
   AREA    test, CODE, READWRITE
SWI_Exit    EQU &11
     ENTRY
    ADR    r0, A
  MOV    r1, #15
  STR    r1, [r0]
  SWI    SWI_Exit
A  =    0
  END
Neither arm-elf-gcc -o arm.elf arm.s
nor arm-elf-gcc -mthumb -Bstatic arm.s -o arm.elf
as suggested on the ARMulator's site are working.
I am already so desperate, as I can't find any proper tutorial or any
more information on that.
So I would very much appreciate ur guys help, as I also need that for my
uni coursework.
Cheers,
Jimmy
Author: Krapao (Guest)
arm-elf-gcc (to be more specific the GNU Assembler) has another syntax
than Keil Assembler. You would need to rewrite this KEIL assembler
source code. Starting points are of course the Keil User Manual and the
GNU Assembler Manual (gas).
Keil:
http://www.keil.com/support/man/docs/armasm/armasm...
gas:
http://sourceware.org/binutils/docs/as/
The line
will translate in something like
.section test, "awx"
or
.section .test, "awx"
If you look in such kind of code, you will find examples in the net e.g.
http://www.zap.org.au/elec2041-cdrom/unsw/elec2041...
that you can use as starter.
Hint: In order to have a section test, you need the proper linker
control script with the memory layout as well! IMHO it's much easier to
look for an assembler tutorial with usage of the GNU toolchain than
struggling with two unkowns - Keil/GNU translation and ARM learning.
