Is there any relation ship between clock and output? Actually i'm using PLL to generate clock of any frequency(1.5 to 350MHz) and using that clock as a reference for the code. If I use sclk freq of 14MHz and i'm changing the upperlimit of count value (indicated using comments in the code) then the real output is not as post synthesis simulated output. ie it works when count="0001000100010111000000" and it is not working when count ="0000111110001001010001" in the if condition. please help....
> ie it works when count="0001000100010111000000" and it is not working > when count ="0000111110001001010001" in the if condition. Why do you not count with integers? Then you can write
1 | if(count>0 and count<49) then ... |
instead of
1 | if(count>"000000000000000000000" and count<"000000000000000110001") then ... |
You have a VERY UNUSUAL way to describe clocked processes:
1 | process(temp1,reset,templock) |
2 | begin
3 | if(reset='1' and templock='1') then |
4 | if(count>"000000000000000000000" and count<"000000000000000110001") then |
5 | if falling_edge(temp1) then --- Huh, a clock. Here? |
Additionally you muddle up combinational and clocked processes. And you also have two clocks in one process:
1 | process(temp1,data,intaddr,reset,templock) |
2 | begin
3 | if(reset='1' and templock='1') then -- first combinational |
5 | if rising_edge(temp1) then -- then a clock |
6 | :
7 | end if; |
8 | elsif(count = "000000000000000110001") then -- then combinational |
9 | if rising_edge(temp1) then -- and again a clock |
10 | :
11 | intaddr<=intaddr+1; |
12 | end if; |
13 | else -- further on combinational |
14 | :
15 | data<=LETTER_DB(conv_integer(intaddr)); |
16 | end if; |
17 | else
18 | intaddr <= "0000000"; |
19 | :
20 | end if; |
21 | end process; |
I urge you to have a close look how others are doing it. Although your description may work (because synthesizers get better each day), you will NOT see this style in any book! > if rising_edge(temp1) then > if falling_edge(temp1) then In a synchronous design there is only 1 clock. Thats the "one and only" system clock. And the whole design uses the same edge of this clock. temp1 sounds not like a system clock... :-/
