Forum: FPGA, VHDL & Verilog help needed in top level creation
Author: sreekanth beee (sreekanthbv)
hi,
i am very new to vhdl coding. so, i  need some help in creating the top
level for two sub modules. i have written the following code for it.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
use ieee.numeric_std.all;
entity system is
Port ( clk : in STD_LOGIC;
       reset : in STD_LOGIC;
       tdata_in : in std_logic_vector(7 downto 0);
       tdata_out : out std_logic_vector(7 downto 0)
end system;
architecture Behavioral of system is
component InternalADC is
    port (
        reset     : in  std_logic;
        clk       : in  std_logic;
        wr        : in  std_logic;
        rd        : in  std_logic;
        addr      : in  std_logic_vector(7 downto 0);
        data_out  : out std_logic_vector(7 downto 0);
        miso      : in  std_logic;
        next_mosi : out std_logic;
        next_sck  : out std_logic;
        cen       : out std_logic;
        EOC       : in  std_logic;
        PowDownAD : out std_logic
end component;
component afsk is
    Port (
            Clk : in  STD_LOGIC;
          bfs1 : in std_logic_vector(19 downto 0);
            bdata_in : in  std_logic_vector (7 downto 0);
            bdata_out : out  STD_LOGIC
end component;
signal bfs1 : std_logic_vector (19 downto 0);
signal data_int : std_logic_vector (7 downto 0);
begin
a : InternalADC PORT MAP (clk, reset, wr, rd, addr, miso, next_mosi,
next_sck, cen, EOC, PowDownAD,
                           data_in => tdata_in,
                           data_out => data_int);
b : afsk PORT MAP ( bfs1, clk, reset, data_int, bdata_out => tdata_out);
end;
but it gives me the following errors when i simulate it...
# ** Error: C:/Actelprj/afsk_top/hdl/top.vhd(52): (vcom-1028) Formal
"data_in" has already been associated in a positional association.
# ** Error: C:/Actelprj/afsk_top/hdl/top.vhd(53): (vcom-1028) Formal
"data_out" has already been associated in a positional association.
# ** Error: C:/Actelprj/afsk_top/hdl/top.vhd(53): VHDL Compiler exiting
# ** Error: C:/Actel/Libero_v9.1/Model/win32acoem/vcom failed.
# Error in macro ./run.do line 14
please help me with this problem..
First you start with positional association, then you turn over to
direct association:
   a : InternalADC PORT MAP (clk, reset, wr, rd, addr, miso, next_mosi, next_sck, cen, EOC, PowDownAD,
Try it with using only direct assigning internal signals
a : InternalADC PORT MAP (clk => clk,
                          reset => reset,
                          wr => the_write_signal,
                          rd => your_read_signal,
                          addr => address,
BTW: here you muddeld up clk and reset.
    port (
        reset     : in  std_logic; -- first reset
        clk       : in  std_logic; -- then clk
        wr        : in  std_logic;
        rd        : in  std_logic;
              --  first clk then reset
a : InternalADC PORT MAP (clk, reset, wr, rd, ...... );
That would lead to funny effects...
And this also:
[vdhl]
[/vdhl]
You MUST use either the old ones:
[vdhl]
[/vhdl]
Or much better the:
[vhdl]
[/vdhl]
But never ever all of them together, because then you will have some
datatytes declared a little bit different, and some functions wre
declared in both of them and so the synthesizer will not know wich
conversions to use...
Hello Mr.Lothar Miller,
Firstly thanks for your response..
for direct assignment of the internal signals, i don't have the inputs
for "wr" and "rd" and rest of the internal signals in the top level
entity.
entity system is
end system;
 so, i have a doubt that how to deal in this situation.
> i don't have the inputs for "wr" and "rd" and rest of the internal
> signals in the top level entity.
You will have to implement those signals. Because thats obviously the
only way you can the component InternalADC...
Author: Duke Scarring (Guest)
> entity.
Ports of type output you can leave 'open'. For input ports you can use
constants:
dac_instance: InternalADC
    port map (
        reset    => reset,      -- : in  std_logic;
        clk      => clk,        -- : in  std_logic;
        wr       => '0',        -- : in  std_logic;
        rd       => '1',        -- : in  std_logic;
        addr     => "00000000", -- : in  std_logic_vector(7 downto 0);
        data_in  => "00000000", -- : in  std_logic_vector(7 downto 0);
        data_out => open,       -- : out std_logic_vector(7 downto 0);
Duke
> constants:
Right, but then the ignored outputs MUST be of no use to the design. And
the component also MUST be able to work without those signals. I cannot
believe that a module with wr and rd signals don't use them...
hi,
thanks for your valuable suggestions... if one of my sub module contains
a generic declaration in its entity.. should i have to declare and
instantiate the generics in the top level as well? if so can any one
guide me how to do it with an example...
  • [vhdl]VHDL code[/vhdl]
