Forum: ARM programming with GCC/GNU tools _sbrk exists, linker can't find it
Author: Liviu Vasut (liviu)
Hello,
I'm trying to compile a program for a stm32f4-discovery board using code
sourcery g++ lite and I'm having a peculiar problem. My program uses the
"new operator" and I had to implement the _sbrk function.
Here is the linker command:
arm-none-eabi-g++ -mthumb -mcpu=cortex-m4 -march=armv7e-m
-mfix-cortex-m3-ldrd -o main.elf -O2  -g -Wall -Werror
-Wl,-T/home/li/dev/arm_rc/ld/cs3.ld  main.o start_cs3.o newlib_stubs.o
_sbrk is in newlib_stubs.c (.o). Knowing that order of the files on the
command line counts, I tried moving newlib_stubs.o as first/last
argument but with no success.
What could be wrong?
Note that the C version of the program that uses malloc is compiling
just fine (arm-none-eabi-gcc instead of arm-none-eabi-g++)
Thanks,
Liviu
Author: Jörg Wunsch (dl8dtl) (Moderator)
Did you perhaps compile newlibs_stubs with the C++ compiler, so the
names got their C++ mangling?
Try running arm-none-eabi-nm on the file newlib_stubs.o, and see
which symbol it is reporting for _sbrk.
Btw., the order of explicitly mentioned .o files on the commandline
(almost) doesn't matter.  It's only the order of library files that
matters.
Thanks Jörg, you made my day!
That was indeed the problem and now it's solved. I learned something
today (again) :).
