Hi This is a beginner problem. I don't know how to compare these 2 types. I got overload error when trying to compare
1 | if keypad(1) = 1 then |
2 | next_state <= 1; |
keypad is a bit_vector(9 downto 0).
Forum: FPGA, VHDL & Verilog VHDL bit_vector overload problemHi This is a beginner problem. I don't know how to compare these 2 types. I got overload error when trying to compare
keypad is a bit_vector(9 downto 0). keypad(1) = '1' beim ganzen Keypad wäre es dann keypad = "xxxxxxxxxx" wobei x entweder eine 1 oder eine 0 sein kann. Also einzelne Bitwerte in ' ' und mehrere in " ". thanks, I saw my error. But my program won't work still. I added it into the attachment. Sorry for the german ... Ok you wrote when 0 => if input = "0000000001" then next_state <= 1; else next_state <= 0; end if; so it depends on the input - how ist the input connected? How long is the input provided? I mean, if the input is only for a very short time not 0, then it is most of the time 0. And then your next_state = 2 and also current_state, because current_state is updated every clock. Edit: The process depends on current_state and input. So if we step along, say current_state=0 and input= "0000000001" then the process assigns next_state to 1. BUT: in the next clockcycle, current_state is updated to next_state, in this case to 1. Because current_state ist updated, the process runs again and now with input still "0000000001" it goes to when 1 => and because input is not "0000000000" the next_state = 0. And so on. Now current_state is updated to 0 and it begins again even if the input doesn't change. I don't know if it helps, but i would test if it works woth only input in the sensitivity list process(input) Please log in before posting. Registration is free and takes only a minute.
