Forum: FPGA, VHDL & Verilog Error creating Nios II application and BSP from template
von Nasas K. (Company: TheCompany) (kycas)
Hello,
I've built my system in Qsys, no errors, generated it, everything was
OK. But when I wanted to create Nios II application and BSP from
template: loaded .sopcinfo file , selected Hello world template and I've
got this error:
SEVERE: .entry section mapping not created because reset memory region
not located at base address 0xffffffffffffffff.
Does anybody know what it means and how to fix it. Please help me.
Regards
Kycas
von Fred Heineman (Guest)
Hello Nasas,
I just came across this post while looking for another topic. Have you
had success getting your design to work?
von liu x. (Company: hanming) (liuxing)
hello,
Nasas and I have the same problem.  I have no way to fix it,please help
me.
the problem is:
region not located at base address: 0xffffffffffffffff
von hans (Guest)
u  reassign adresses in qsys and generate after it?
von Tom (Guest)
Had the same problem, sovled it by :
- in QSYS->System Contents , right click your Nios cpu -> Edit...
- in the tab "Core NiosII", check if "reset vector memory" points to a
memory module and not e.g. jtag etc.
- same with "exception vector memory"
- after correction : QSYS->Generation->Generate
von Robert (Guest)
@Tom, you're totally right. Your answer helped me to fix my problem.
von Alexander (Guest)
Thank you very much! It helps me too.
