Forum: ARM programming with GCC/GNU tools Yagarto on Linux - GCC 4.6.2 4.6.2 zlib GCC_NO_EXECUTABLES error
von Drasko D. (drasko)
Hi all,
I am compiling Yagarto for Linux using MAC build scripts.
It works more or less fine, except GCC build without adding
--with-system-zlib option (as it is not added in Yagarto buildscripts by
default).
I am hitting :
configure: error: Link tests are not allowed after GCC_NO_EXECUTABLES.
Apparently, there been experiences with this bug
(http://www.mailinglistarchive.com/html/gcc-help@gcc.gnu.org/2011-03/msg00327.html).
Also, here
http://cu.rious.org/make/compiling-the-arm-cortex-m4-toolchain-yourself/
the same workaround (-–with-system-zlib: Fixes the error: configure:
error: Link tests are not allowed after) has been noted.
I tested it, and it works.
I have two questions :
1) --with-system-zlib overrides this bug, but how this affects
produced binary (what is the differences in using system or non-system
zlib) ?
2) Is there a patch to this bug (it would be easier to add the patch,
then to demand that every user has system zlib installed) ?
Best regards,
Drasko
von gcc-help@gcc.gnu.org (Guest)
