Forum: ARM programming with GCC/GNU tools Count external pulses using LPC1768
von Joseph C. (Company: MagicKingdom) (jchan12345)
Anyone knows how to count external pulses using CAP0.0 of LPC1768 ?
Do you have a working code ?
Here is my code but it does not work.  Don't know why I always read 0
from LPC_TIM0->TC with external pulses going into P1.26.
//Set PINSEL3 [21:20] = 11 for P1.26 as CAP0.0
LPC_PINCON->PINSEL3 |= (0x3 << 20);
// set pin P1.26 as input
LPC_GPIO1->FIODIR &=~(1<<26);
// PCTIM0 Timer0/Counter0Power On
LPC_SC->PCONP |= 2;
// Counter Reset
LPC_TIM0->TCR = 2;
//Counter Mode:TC incremented on rising edges on the CAP0.0 for
// timer0
LPC_TIM0->CTCR = 1;
// Capture on rising edges on the CAP0.0.
// TC -> CR0
LPC_TIM0->CCR = 0;
// Counter Enable.
//LPC_TIM0->TCR = 1; // I try 1 too and it still does not work
LPC_TIM0->TCR = 0;  // 0=Enable from data sheet
von A mirzaee (Guest)
use this code
#include <RTL.H>
#include <LPC17XX.H>
#include <Ports.H>
#include <LCD.H>
#include <uart.h>
static char in_line[160];
int pos = 0;
int i;
void ComProc()
    myLog((u8*)&in_line,3);
  if ( strcmp(in_line,"cls") == 0)
    cls();
  for ( i=0; i < 160; i ++ )
  in_line[i]=0;
  pos = 0;
void EnableCntr0()
  LPC_SC->PCONP |= 2;
  // Counter Reset
  LPC_TIM0->TCR = 2;
  // timer0
  LPC_TIM0->CTCR = 1;
  // TC -> CR0
  LPC_TIM0->CCR = 0;
  // Counter Enable.
  LPC_TIM0->TCR = 1;  // 0=Enable from data sheet
void EnableCntr2()
  //Set PINSEL0 [9:8] = 11 for P0.4 as CAP0.0   --->p0.5 ;ar mikonad
   LPC_PINCON->PINSEL0 |= (0x3 << 8);
  // set pin P0.4 as input
  LPC_GPIO1->FIODIR &=~(1<<4);
  // PCTIM0 Timer1/Counter0Power On
  LPC_SC->PCONP |= 2;
  // Counter Reset
  LPC_TIM2->TCR = 2;
  //Counter Mode:TC incremented on rising edges on the CAP2.0 for
  // timer1
  LPC_TIM2->CTCR = 1;
  // TC -> CR0
  LPC_TIM2->CCR = 0;
  // Counter Enable.
  LPC_TIM2->TCR = 1;  // 0=Enable from data sheet
void EnableTimer2()
  LPC_SC->PCONP |= 2;
  // Counter Reset
  LPC_TIM2->TCR = 2;
  // timer1
  LPC_TIM2->CTCR = 0;
  // TC -> CR0
  LPC_TIM2->CCR = 0;
  // Counter Enable.
void EnableCntr1()
//Set PINSEL3 [5:4] = 11 for P1.18 as CAP1.0
 LPC_PINCON->PINSEL3 |= (0x3 << 4);
//LPC_PINCON->PINSEL3 |= (0x3 << 7);
// set pin P1.18 as input
LPC_GPIO1->FIODIR &=~(1<<18);
LPC_GPIO1->FIODIR &=~(1<<19);
// PCTIM0 Timer1/Counter1Power On
//LPC_SC->PCONP |= 2;
// Counter Reset
LPC_TIM1->TCR = 2;
// timer0
LPC_TIM1->CTCR = 1;
// Capture on rising edges on the CAP1.0.
// TC -> CR0
LPC_TIM1->CCR = 0;
// Counter Enable.
LPC_TIM1->TCR = 1;  // 0=Enable from data sheet
int main()
  char c=0;
  u8 prn[100];
  int cntr0;
  int cntr1;
  int cntr2;
  //const unsigned long TCR_COUNT_RESET = 2, TCR_COUNT_ENABLE = 0x01;
  SystemInit();
  LPC_GPIO2->FIODIR |= 0xFF; // P2[0..7] =
  LCD_Init();
  LcdLog = 1;
  LCD_Clear(White);
  LCD_SetBackColor(Red);
  LCD_SetTextColor(Blue);
  UART2_Init();
  logstat=1;
  myLog("Started...",1);
  myLog("LCD--->OK",2);
  myLog("Start UART2",3);
  Uart2Log =1;
  myLog("UART2--->OK",4);
  cls();
  EnableCntr0();
  EnableCntr1();
  //EnableCntr2();
  EnableTimer2();
  while(1)
  cntr0= LPC_TIM0->TC;
  cntr1= LPC_TIM1->TC;
  cntr2= LPC_TIM2->TC;
  sprintf(prn,"%d %d %d %l \n\r", cntr0,cntr1, cntr2);
  UART2_SendString (prn) ;
    c = getkey();
  if ( c != 0 && c != 13)
    in_line[pos++] = c;
    LCD_ShowString(1,19*16, in_line);
  if ( c== 13 )
     ComProc();
von Ramana M. (Company: Duffifie) (alchemist2805)
How to count the external low pulses (low occupancy time)?
As in above code, Counter Mode:TC incremented on rising edges.
I using the PPD42NJ particle matter sensor, which is to count the low
pulse occupancy time.
Reply will be appreciated.
Thanks
von JojoS (Guest)
The counter mode is the wrong mode when you want to measure pulse width
times. At first, you should get the user manual for the LPC176x, its
UM10360.
Then you need to configure a timer that runs with a clock with the
desired resolution of the measurement. If you want 1 µs resolution the
clock must be set to 1 Mhz.
Then set CCR to capture rising and falling edges and generate an event.
In the ISR, you need to check the input pin if a falling or rising edge
occured. On a falling edge, save contents of the CR (capture register)
as start time. On a rising edge, save CR as stop time and add the
difference to a sum counter.
For the same counter, you can program a MATCH register with a value of
30e6 and create another interrupt. This will fire after 30 s for the
final calculation of on-off times.
Thanks for your reply JojoS ,
As you mentioned, am trying to read the low occupancy time in the ISR
with Rising Edge and falling Edge. So, initially am trying to see the
time in UART for both rising and falling edge.
I have done the changes, But still am not able to enter in ISR - if
condition. Please see the attached code.
Let me know, if any suggestions
Thanks
von JojoS (Guest)
this condition will never become true:
   if((LPC_TIM0->IR & (1<<4)) == 0x01) // if MR0 interrupt
   // try this:
   if((LPC_TIM0->IR & (1UL<<4))) // if MR0 interrupt
Also it is no good idea to use printf() in an ISR. For testing it may
work, but depends on the code for the output device. It is better to
collect the results in an array and print that in the main().
But at least the interrupt indicator LED1 should toggle on the capture
interrupt.
