Forum: ARM programming with GCC/GNU tools static code analysis
von Ralf G. (rgl)
Hi @all,
i'm currently evaluating software solutions (open source when possible)
for static code analysis to be used on C sourcecode.
Toolchains used are avr-gcc and arm-gcc.
Has anybody experience with the use of those tools for embedded
development and can suggest a good solution?
Best regards,
Ralf
von Code Testing (Guest)
Have you checked out this list?
http://en.wikipedia.org/wiki/List_of_tools_for_static_code_analysis#C.2FC.2B.2B
At work we use a commercial tool (Klocwork). I'm not really familiar
with the open source ones.
von Ralf G. (rgl)
Yes, i did.
Unfortunately it's just a list without any comparison of the tools. I'm
looking for the opinion of people who are actually using a code analysis
tool with their cross gcc toolchain.
BTW what about the Klocwork tool? Is it beneficial? What toolchain are
you using?
von Just me (Guest)
I've worked with Lint, splint and QA-C, whereas the first and the latter
one are commercial tools. Splint hasn't been updated for a long time -
it seems to me that the development has been stopped.
I don't understand why you ask for the (compiler-) toolchain - do you
expect any special dependencies between the compiler and the code
analysis tool?
von Just me (Guest)
...beside the programming language itself?
Yeah, I also don't really see what difference it makes what
compiler/toolchain you are using. It's the source code which gets
analyzed after all. Unless maybe you are compiling the Linux kernel
which needs gcc-specific extensions?
Klocwork Insight is pretty solid, but also not cheap. Not feasible for
private users, only for companies I should think.
Using it is certainly beneficial. Unless you ignore what the tool finds
and leave your code as it is ;)
von Ralf G. (rgl)
I'm asking for the toolchain out of two reasons:
1. the supported (required) language standard (we use gnu99 C standard
as all our toolchains are recent cross gcc's, splint on the other hand
only supports C89)
2. there is some effort to make microcontroller specifics known to the
code checker (ISRs, hardware registers etc.) and if someone already has
done this i might not need to do it myself
von Just me (Guest)
Alright.
Did you already play with the different code check settings of your
compiler (gcc)? Most recent compilers can be configured to do a lot of
code analysis by themselves. This might not be a replacement for the
code analysis tool, but it's better than nothing ;)
von Ralf G. (rgl)
I did and i'm using Eclipse's CODAN but i would really like a little
more in-depth analysis
von mfq (Guest)
While splint is an easy-to-use (but somewhat limited) tool with fast
results it does only ANSI C and fails spectacularly if applied to a C99
oder even gnu99 codebase. As was already mentioned development on it has
stopped more or less. As far as I know there are no plans for C99
support.
Today's compilers are able to give most of splint's warnings when set up
appropriate.
An interesting project that might have a bright future is the Clang
frontend for the Low-Level Virtual Machine. Usage of libclang by
development tools might make stuff possible that previously was reserved
to other languages.
There's also a static analyzer built on top of it:
http://clang-analyzer.llvm.org/
The project is a WIP still under heavy development but at least for C
(as opposed to C++) it's results are already usable.
They also aim for high compatibility with GCC.
