Forum: FPGA, VHDL & Verilog square root and cubic root for integer and FPGA implementation
von Detlef _. (detlef_a)
This post refers to:
Beitrag "Kubikwurzel bilden"
The attached C-code implements square root and cubic root calculations
for integers. The code uses mere Add/Shift operations and is thus well
suited for hardware implementation.
It was assembled and adapted from different sources.
There are more details given in the attached file.
Cheers
Detlef
: Moved by Admin
von Mohan (Guest)
Do you have any material guidance on how to implement cubic root using
FPGA - with matlab SIMULINK?
Any help is greatly appreciated .
Thank you
