Forum: FPGA, VHDL & Verilog Can I use a 'block array' as an entity i/p or o/p
von David O. (mucker2b)
Hi - can anybody tell me if it is possible to use a 'block array' as in
input or output when describing an entity.
For example;
port (a: in std_logic;
      sel: in std_logic_vector(1 downto 0);
      y0: out std_logic;
      y1: out std_logic;
      y2: out std_logic;
      y3: out std_logic);
can be simplified to
      y: out std_logic_vector(3 downto 0));
I have a 32bit mux with 32 inputs and I was wondering if I could
simplify the entity in a fashion similar to the single array example
above.
port (a: in std_logic_vector(31 downto 0);
      sel: in std_logic_vector(4 downto 0);
      y0: out std_logic_vector(31 downto 0);
      y1: out std_logic_vector(31 downto 0);
      y2: out std_logic;
      y31: out std_logic_vector(31 downto 0));
Thanks,
David
von user (Guest)
yes this is possible, you habe to define a data-type and then use this
type
type mytype is array(0 to 31) of std_logic_vector(31 downto 0);
      y0: out mytype;
Thanks for the response
> you habe to define a data-type and then use this type
Of course you will have to do this type definition inside a package. And
then include this package in your vhdl file...
So it looks like this:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
package mytypes is
end mytypes;
-- and then (may be in another file)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use work.mytypes.all;
entity test is
    Port ( i : in  mytype;
           o : out mytype
end test;
Hi Lothar,
The following code is what I have done.
library IEEE;
package block_arrays is
type block_array is array (0 to 31) of std_logic_vector(31 downto 0);
end block_arrays;
library IEEE;
use work.block_array.all;
entity ram_mux_32_1_nbit is
generic(n:integer:=32);
port(  sel: in std_logic_vector(4 downto 0);
  x: in block_array;
  y: out std_logic_vector((n-1)downto 0));
end ram_mux_32_1_nbit;
architecture Behavioral of ram_mux_32_1_nbit is
begin
with sel select
  y <= x(0) when "00000", (others => 'Z'),
             x(1) when "00001", (others => 'Z'),
             x(31) when "11111", (others => 'Z'),
       (others => 'Z') when others;
end Behavioral;
The testbench looks like this though - x is seen as a single array
 COMPONENT ram_mux_32_1_nbit
    PORT(
         sel : IN  std_logic_vector(4 downto 0);
         x : IN  std_logic_vector(0 to 31);
         y : OUT  std_logic_vector(31 downto 0)
    END COMPONENT;
When I try to give x a value in the testbench;-
x(0) <= "00000000000000000000000000000001";
x(31) <= "10000000000000000000000000000000";
.....I get the following error:-
Type std_ulogic does not match with a string literal.
Would this be because of the component declaration only being seen as a
std_logic_vector?
> as a std_logic_vector?
Yes.
So, it is YOU, who wrote a WRONG port definiton inside the test bench.
And if the toolchain did it, it was YOU, who did NOT CORRET it. Ports
other then std_logic is something the "semi-automatic" tcl-script in ISE
can't cope up with! Its YOUR job to get the correct components in your
upper-level modules (like a testbench).
To keep things short:
The component in the testbench must be the same as the entity! So you
must edit to get the same ports:
    PORT( sel: in std_logic_vector(4 downto 0);
          x: in block_array;
 end component;
I thought the testbench software was gospel - didn't realise they could
be wrong also. Thanks again!
